rusted out battery tray....need help
Old Oct 28, 2002 | 10:23 AM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
Has anyone ever replaced their battery tray in their fbody? Im surprised my battery was even still in the car considering the rust hole under neath it.
Any tips on how to do a fix? Does GM or anyone else sell a replacement piece. I think I heard somewhere that the tray is removable and you just need to weld in a new piece. Any help????
Old Oct 28, 2002 | 11:56 AM
LT1guy's Avatar
Car: 1987 Trans Am
The original is spot welded in. I don't know if anyone offers a new replacement, but you might want to check with Year One or Classic Industries. If no luck there, call Bruce Hawkins at Hawk's Third Gen (864-855-2694); he could probably cut one out of a wreck for you. They should be fairly easy to drill out and reweld.
Old Oct 28, 2002 | 12:00 PM
Thanks for the tip. How hard will it be to remove the original...I would guess just chizeling it out?
I'll check into Year One. Thanks.
Old Oct 28, 2002 | 12:10 PM
LT1guy's Avatar
Car: 1987 Trans Am
I'd reccomend using a spot weld cutter, available from the Eastwood Company and most tool suppliers. That way you'll do less damage to the car taking it out.
Old Oct 28, 2002 | 01:13 PM
never heard of one but I'll look into it. I just got a new house and Im trying to get my garage in order. Sounds like a tool Im going to need.
Thanks again man. Your a big help. I hope I can fix this problem.
Later,
bill
Old Oct 28, 2002 | 02:17 PM
Z28DJP1987's Avatar
Just remenber that the original battery tray is part of the front fender support. So I would be carefull how I take it out and put the replacement in.
Old Oct 28, 2002 | 03:27 PM
MdFormula350's Avatar
i would patch the hole and then put some heavy duty rust sealant on it and then spray paint it black..
i would trust myself to cut my car at least that is what i would do!!
Old Oct 28, 2002 | 03:46 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I removed both of my battery trays for weight reduction, looks, and a cold air intake when I painted the engine bay last summer. (My battery is in the back) I simply drilled out the spot welds, chiseled out the rusty trays, ground the edges smooth ruberized coated the inner bumper and fender, and reprimed and painted it all. The same methods can be applied to removing your existing battery trays for replacement. They are supposed to be removable/replaceable. You should be able to aquire them through classic industries or your chevy dealor. Just tack weld a new one back into place.
Old Oct 28, 2002 | 03:52 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Mines starting to rust so i was gonna poke out all the rust grind it back down to bare metal and weld a piece of galvenized steel over it and prime paint ect then put a battery tray over the new peice so it'll last longer (hopefully)
Old Oct 28, 2002 | 03:55 PM
thanks for all the tips. I could just do a quick fix but I since I no longer daily drive my firebird I am garaging it to do a full (or to my best ability) resto of the car. I would like to make it respectable enough to show. at least thats my intention.
I will try and get a correct replacement and remove the old and put in the new.
Thanks again.
Old Oct 28, 2002 | 04:22 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
Poor baking soda on it. It will fizz up and neutralize the battery acid.
Old Oct 28, 2002 | 04:47 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Use bondo, It's the only way to go! j/k
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Grant2k
Apr 4, 2016 08:21 AM
Johnoooooo
Sep 22, 2015 08:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
