Trouble replacing hatch shocks...
Old Jan 27, 2003 | 08:56 PM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
i had no problem getting the ratchet bolt off of the hatch window but i cannot seem to get bolt that is attached to the panel right by the back seats
i know its probably something that i havent tried but to be honest i havent the slightest idea on how to do it
Old Jan 27, 2003 | 10:14 PM
chitowncruiser's Avatar
Car: 1996 Camaro
Engine: 3800 V-6
Transmission: 4L60E Automatic
90...........the way I did mine on my Firebird was this.......take a pole and hold the rear hatch up with it to support it and your not holding it up....take off the rear ones first and let them down so no weight is on them....torque or star socket for the ones behind the seats with a 1/2 breaker bar.....once they have broken loose just use a regular wratchet to take them off........installation is reverse....shouldnt be no problem with it..just take your time doing it...........good luck.....
Old Jan 27, 2003 | 10:16 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
They use torx/star or tamper proof bits to take them off. Just be sure to have somebody holding the hatch or leave it closed when taking them off and putting the new ones on.
Old Jan 27, 2003 | 11:22 PM
joshp14's Avatar
the size i believe is a T-50 torx bit, sears sells them. craftsman makes them...stock #42667...if they don't have any, you are going to have to by 'leslie' brand.
Old Jan 28, 2003 | 09:35 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I think it's actually a T43. But it may be a T50. I have the exact one at my house. I'll have to look at it later.
BTW a hockey stick without the blade on it works perfectly to hold up the rear hatch.
Old Jan 28, 2003 | 09:54 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
what thirdgen owner doesn't have "The Stick"
btw it works much better, if you take one shock off, then put the new one on, then take the other off.
it can turn into a PITA if you take both off.
Old Jan 28, 2003 | 12:22 PM
ReynoldsJK's Avatar
where did you get them, and how much were they?
Old Jan 28, 2003 | 01:17 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Dont have the hatch closed or you'll get one hell of a suprize when the shaft fully extends it'll, unless you have the shock fully extended already. Lol I need to get new shocks for my hood and hatch.
Old Jan 28, 2003 | 01:32 PM
joshp14's Avatar
just get your self an extra set of hands to hold up on the hatch's other side when you are replacing one of the shocks. It would put a lot less stress on the hatch if you have someone hold it up rather than letting one side hold up the whole hatch.
Old Jan 28, 2003 | 02:32 PM
Car: 1996 Camaro
Engine: 3800 V-6
Ohhhhhhhhhhhh. Yes the " Stick " is a wonderful item to have when working on the hood and rear hatch, especially when you dont have that extra set of hands to hold it up.............just make sure you apply some grease on the threads before you put it back on to help ease removal next time.......... :lala: :lala: :lala:
Old Jan 28, 2003 | 02:42 PM
Dewey316's Avatar
Car: 1990 Camaro RS
of course i found a pair of vice grips much easier than the stick (you just clamp it on the stock :-D
Old Jan 28, 2003 | 03:01 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
id like to know too, my hatch and hood shocks all need to be replaced. how much total price am i looking at for 4 new ones?
Old Jan 28, 2003 | 03:06 PM
joshp14's Avatar
about $100.00 for all 4
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
EFR2000
Aug 18, 2015 08:54 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
