Power window install
Old Feb 22, 2003 | 10:28 PM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Transmission: broken
I have a 1990 rs w/ manual windows, and I really want power windows. How hard would it be to swap the manual out for power, would I just be better off buying two new doors?
Old Feb 23, 2003 | 08:24 AM
scott's85T/A's Avatar
Try this.
http://www.p71interceptor.com/thirdgen/powerwindows/
If you are really interested. I have a complete setup in my garage I'm thinking about selling, Drop me an email with an offer.
I have the window reg. with the motors,wireing, but only one of the switches.
Old Mar 9, 2003 | 01:25 AM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
what do you want for it? i might be interested.
Old Mar 9, 2003 | 02:20 AM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
I've done the swap twice already, following the link above. It's actually very easy to do (atleast I find it was) The first swap I gutted the whole interior to do, second swap just took out the front seats & pulled back the carpet. Took about 4hrs to do
One more swap to complete yet
Old Mar 11, 2003 | 10:30 PM
Engine: 357
but is it worth the money and trouble just to have power windows?
Old Mar 12, 2003 | 10:33 AM
rockfourone's Avatar
its not that hard in theory but it takes PATIENCE!!!!! just to do 1 door took me all weekend. if you dont already have a dremel, id go buy one with about 20 cutting wheels, those rivets are a B*TCH!!!!
good luck to ya....
Old Jan 11, 2004 | 01:22 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i am awanting to swap from original power over to manual in my 82 trans am, so if someone wants to do some parts swapping then lemme know, i am going to gut the doors on the car here once i find out what all parts differ between power and manual
thanks
Old Jan 11, 2004 | 02:27 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Replaced my power window motor yesterday, not as hard as some would make you believe, but patience is definatley key
Old Jan 11, 2004 | 03:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey rockfourone,
If you ever have to change out another window regulator, just take a small punch and knock the center pins (if there) out of the rivets and then use a drill with a 1/4" drill bit to drill the heads off. About 15 seconds a rivet.
The Trickster!!!!!!!!!!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
stalkier
Aug 13, 2015 12:59 PM
