interior redone
Old Apr 30, 2003 | 01:52 PM
3rdGenSuperman's Avatar
Car: 1983 Camaro Z28
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
interior redone
in the next few weeks i will be starting a restoration of my interior. Do door panels come in any other color, the only 3rd gen ones i have seen are grey?
Oh and one thing for everyone else to do for the plastic parts, i heard you can sand the old finish away, prime it and paint it whatever color you want. is that possible?
Old Apr 30, 2003 | 01:55 PM
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
lights
another thing im curious about, has anyone tried to do a swap from the double headlight to a single, if so how difficult was it, and what all needs to be redone
Old Apr 30, 2003 | 03:40 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
There's a new rattle can paint out.. Fusion(?)
It molecularly bonds with the plastic.. Maybe someone else will chime in and explain more..
Priming/painting sucks. It will scratch with normal paint.
Old Apr 30, 2003 | 03:42 PM
Edmonchuck's Avatar
Engine: L98 TPI
I've recently used Fusion on my panels, and it ROCKS! No priming, and after sitting for a week, it does not scratch off. Sure, if I took a sander to it, it will go away, but overall, it is great.
Old Apr 30, 2003 | 06:52 PM
HanSoloWS6's Avatar
Car: '05 Pontiac G6
Engine: 3.5
Axle/Gears: Slow lol.
Re: lights
I have not personally done this, but I was going to buy an 86 El Camino with the Camaro nose and it had the single lens assembly. It was a kit from Lauren Engineering I think. But in a nutshell, it uses the head lights and I think brackets from a early 90's Caprice. You might be able to pick up all the needed parts and wiring for around $100 give or take a few bucks. It's a nice look though. You'll need probably all the brackets, harnesses, relays and whatever else. Check Lauren Engineering at http://www.laureneng.com . There should be a listing for just the kit or you could call or write about it.
Old May 1, 2003 | 12:13 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Door panels seem to come in grey, black, red, tan, and brown. Those are the only interior colors our cars came in as far as I know.
Old May 1, 2003 | 01:33 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
and blue!
Old May 1, 2003 | 08:49 AM
87WS6's Avatar
Really? I have never seen a blue interior in one of these cars. Not even at the Bone Yard.
Learn something new every day.
Old May 1, 2003 | 08:51 AM
transam305's Avatar
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
lets see pics of it when your done.
Old May 1, 2003 | 09:29 AM
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
thanks
i was hoping for blue, that would be great. ill check on the fusion paint (do you know where i can get that). i will also look into the light setup. and i will defnately get pics
Old May 1, 2003 | 09:57 AM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Be careful sanding your interior panels or you'll remove some of the grain that's molded in. It's better to find the plastic panels in the color you want, if possible.
BTW, if you type in "camaro (or firebird) door panels" on eBay, you'll usually find a bunch of colors on there.
Old May 1, 2003 | 12:09 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've got a blue door panel in my attic that came out of an 83 Z28.
birdman_29
Jan 7, 2017 08:24 AM
Veaceonee
Sep 29, 2016 08:15 PM
86IROC112
Nov 27, 2015 09:54 AM
Denricci22
Sep 18, 2015 09:02 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
