Replacing shift knob in 89
Old May 7, 2003 | 12:33 PM
Flare's Avatar
Replacing shift **** in 89
I have an 89 RS and I bought an aftermarket shift **** but I can't get my old one off. If anyone knows how to remove the stock shift ****, please help me out. Thank you!
Old May 7, 2003 | 01:04 PM
383 rocket bird's Avatar
Automatic or manual?
Old May 7, 2003 | 03:56 PM
Flare's Avatar
manual
Old May 7, 2003 | 05:07 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Originally posted by Flare
manual
turn it, it screws on
Old May 7, 2003 | 05:15 PM
FRDH8R's Avatar
Should be "Righty Tighty" "Lefty Loosey"
I just took mine off the other day, and it twisted right off (turn counter-clockwise to unscrew).
Old May 7, 2003 | 05:48 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Anyone know how to get an automatic shift **** out of an 83 by any chance?
Mike
Old May 7, 2003 | 06:19 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Mike
Remove the clip in the front of it, pry it out with a small screwdriver its like this
Front
Rear
Old May 7, 2003 | 06:35 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Ok, how do you get the button off? What I am doing is replacing the old **** with one in better condition. I just want to make sure I don't break anything. Thanks.
Mike
Old May 7, 2003 | 08:19 PM
Les's Avatar
Les
Shift ****-
I have ran into two syles-
1 the clip is in the front of the shifter **** and is U shaped you simply pry it out and the **** comes out all together.
2. the button must be pulled off (simply grasp with hand and pull up) and under the button is a C clip which you remove and the **** body comes off.
Old May 7, 2003 | 10:07 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Just got back from trying to replace the ****. My 83 had the type where you have to pull the button off then you have to remove the C clip. The C clip is a little tricky to get off. After I had the **** off and tried to put the one I got from a junkyard on, it would not fit because it only had one tab and it was wider that the ones on my 83 Oh well, at least I know how to remove everything now. All I have to do is go back and get one similiar to mine. Thanks for all the help.
Mike
Old May 7, 2003 | 11:42 PM
JAKEDPLAYA's Avatar
is there anyway that someone could get that hammerhead B&M shifter handle onto stock 89 auto shifter????
Old May 8, 2003 | 02:20 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
auto or manual? auto no it can not be done, manual yes it screws on
Old May 8, 2003 | 03:37 PM
Flare's Avatar
Well I have the manual, and I'm a fairly strong guy, and for the life of me I can't screw it off, so does anyone know how you get it off, because I really don't think it just screws.
Old May 8, 2003 | 03:41 PM
Transmission: autos
try some vise grips, or maybe a pipe wrench, but it does screw off, i had a 85 with a manual and it was hard to get off but did come off
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
mizz0313
Aug 12, 2015 06:45 AM
