Removing side mirror
Old May 20, 2003 | 02:31 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Hi,
I have the door panel off at the moment and the bolts taht hold the mirror on seem to be almost impossible to reach. Anyone have any handy tips? I am replacing the black plastic type gasket as it is cracked.
Cheers,
Felix
Old May 20, 2003 | 06:29 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I simply used an extension on my ratchet (make sure you snug the bolts up. After repainting the car and, of course, removing and replacing the mirrors, both eventually loosened up so that I had to go in again). By the way, since you're in the door panel anyway, you might consider cleaning and relubing the window tracks as well as the power locks. Should you have rattles, as most thirdgen cars do, check the following post:
https://www.thirdgen.org/techbb2/sho...hreadid=124084
JamesC
Old May 20, 2003 | 06:33 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
JamesC- you are the inspiration for me to take the door apart at all I have saved acopy of your observation e-mail. Should be in the tech articles for sure! You are the man and I thank you! Thanks for the help.
All the best
Felix
Old May 23, 2003 | 11:18 AM
uk89camaro's Avatar
Felix,
I replaced my side mirror a couple of weeks ago. Sumbeech crashed into me. I had to take the front window runner out because the black triangle at the top was busted. It's only 2-3 bolts, and you get great access to the door mirror bolts after that.
Cheers,
Paul
Old May 23, 2003 | 12:17 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Yes, a ratchet with extention worked for me, too. Where did you order the gasket? I need one for my passenger side mirror but I don't want to order it from the US since shipping will cost more than the part itself.
Old May 23, 2003 | 05:08 PM
eddie jr's Avatar
JamesC - You mentioned clening and lubing the window tracks. How did you do that??? I have sand caught in mine and the comressed air idea doesn't work too well because the tracks are not very accessible.
thanks,
Eddie
Old May 24, 2003 | 01:42 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Cheers all,
Freeze, I got the gasket from German Motorsport- see the posts on the Europe Board. Excellent service and no ugly import duties.
I realise now that to access one of the bolts it is far easier with the window down! Makes access 100% easier!
Job done, waxoyld, runners lubricated, power locks working again and upgrade to later rod holders (thanks again JamesC)
Paul I remember that incident well! Have you got any compensation from her yet?
Cheers,
Felix
Old May 24, 2003 | 03:08 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Thanks, but I've dealt with him and I'd rather order a part from the states or have it custom made before doing it again.
Old May 24, 2003 | 04:25 PM
uk89camaro's Avatar
Cheers,
Felix
Front shunt, to an agreed claim, to out of the bodyshop=10 days. Gotta be some sort of record.
Old May 25, 2003 | 02:00 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Hey Freeze,
In which case contact thirdgen resource- link is above and ask them.
Paul, that is awesome- still a silly cow though!
Cheers,
Felix
Old May 27, 2003 | 07:31 AM
JamesC's Avatar
eddie,
In order to access the window tracks and the power lock mechanisms, you must remove the door panel and splash shield. Once removed, you'll be able to see what's what.
Felix,
I'm glad all went well.
JamesC
Old May 27, 2003 | 03:24 PM
eddie jr's Avatar
JamesC - yes, i've got the door panels off (and vapour barrier) but the tracks are not that accessible and even facing the opposite way if I remember correctly. I was just wondering how you actually "cleaned and lubed them" because I have sand actually stuck in the grease, so it doesn't come out easily (already used an air gun and compressor).
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
stalkier
Aug 13, 2015 12:59 PM
89FormulaMan
Aug 10, 2015 10:01 PM
3rdgenparts
Aug 8, 2015 07:09 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
