LOOKY LOOKY what I just installed :)
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
It's from SR Motorsports for the Z28. I came across a 140mph speedo from a wrecked Z28 to put in my RS and decided it was time to go INDIGLO
The pictures are not showing up for some reason. Let's see if this works.
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I don't like how you can see the shift, seatbelt, etc. lights on the tach. Other than those, they look sweet.
yeah the dark spots suck but you get used to them after a while. now i'm gonna have to recalibrate the speedo because right now it reads 15mph too fast.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by Spdfrk1990
man i want to get 1 of those and why does it read 15 mph off did u change the gears
if it was off because of gearing, it would be off by a percentage.
im willing to bet that he had to take the needle off to put the overlay on, and he put it on 15mph off.....
when the ignition is not on the needle will rest on the little peg like it is. Once you turn on the ignition then the needle will move up a bit to 0. the reason it's off is because the original speedo is 110mph. there's some info in the other boards about calibrating it.
it reads too fast because i have 3.73's as opposed to the original 3.08 gears that came with the car. also the vss(vehicle speed sensor)still thinks i have 3.08's gears on.
ok so its just from the gears?
Yes I believe so. From my understanding all I have to do is swap out the VSS gears and tailshaft gear with a 15tooth/45tooth one and it should correct the speedo but that's covered elsewhere in another board.ok so its just from the gears?
I switched my gears and the speedo shop said it wasnt far off and was gonna charge me alot so i left it alone. I went from 3.08 to 3.27 it been that way awhile. I was gonna put a 6 speed in later and get that dakota digital box and supposely you can fix it with that. Im not 100% sure exactly how to do it tho
I hear it's a pain in the a$$ to hook up the dakota box. There's supposedly an easier setup out there but costs more. You can find it here http://www.dragonaero.com/SpeedChangerPage.htm
gixxer92
Sep 1, 2015 04:32 PM
Reverse indiglo rules! lol
