T-Tops: On or Off at the strip
Old Aug 3, 2003 | 08:16 AM
darkangrydragon's Avatar
Okay, I'm not sure if this is the right forum, but there's a lot of info on T-Tops in this section (Thx, guys & gals)!
Anyway, does anyone know if it would be better to take off your T-Tops when running the 1/4 (less weight)? Or should you keep them on (reduce drag)?
I am considering acryllic t-tops, but have doubts due to the cracking, crazing, etc. However, I would like to reduce as much weight as possible for when I get around to taking the bird to the track.
If racing w/o the T-tops adds too much drag (ie: more than would be compensated for the lighter weight), maybe I will get a set of plastic t-tops for track only.
What do you guys think?
Old Aug 3, 2003 | 08:19 AM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I don't think any competent track official would let you go down the track with the tops off.
Old Aug 3, 2003 | 08:24 AM
Yeah, but it's soooo hot at the track!
That's a good point, thx Nasty. I guess I'll have to consider el crapo (er, I mean plastic) t-tops. Well, if I only use 'em at the track, I'm sure they'll last.
Anyone know the weight difference between the stock glass and acryillic t-tops?
Thanks!
Old Aug 3, 2003 | 08:35 AM
MartinCadek's Avatar
as far as I know any NHRA/IHRA track will not let you run with the t-tops off
Old Aug 3, 2003 | 08:46 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
You don't want to run without them anyway, they are heavy, but do add some structural support. "some" is the operative word here.
Old Aug 3, 2003 | 05:19 PM
25THRSS's Avatar
Without them your aerodynamics suck too!
Old Aug 3, 2003 | 07:45 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I don't have actual weight numbers to give you. But I was actually able to compare a Lexan top and a glass one at the same time at the junk yards. I would have bought the Lexan Top except it was in bad shape and there was only one of them.
At any rate. The Lexan top was MUCH lighter. I am not sure how much you could possibly shave off of your car. I don't even think it would be worth it. But every bit counts right?
Old Aug 3, 2003 | 08:41 PM
DeathDealer's Avatar
Car: 1992 RS Camaro
Engine: 5.0 L03 TBI 305
Leave them on!
If you take them off you might as well be draging parachutes behind you!
Old Aug 4, 2003 | 07:26 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If you want the Acrylic tops for dragging get a set and use them just for that, then use your glass tops for every day driving...
They are interchangable, but usually the adjustments are differnt.
John
Old Aug 4, 2003 | 05:26 PM
Engine: LB9/383
I honestly don't think the benefits are worth the trouble. If you think about it, the rule of thumb is 100lbs. is worth a tenth in the 1/4. The weight difference of the ttops is maybe 5 lbs. You do the math. You could get a better gain in ET by just learning to drive a little better, or saving the weight in another area of the car. Put some skinnies up front, take out the back and passengers seat, take out the ttop bag and some of the trim pieces from the trunk. You can gain quite a bit by tuning up the engine too.....plugs, wires, advance the timing a bit, yadda yadda. Bottom line, don't worry about the ttops!!!!!!
Old Aug 5, 2003 | 03:30 AM
LetsRock's Avatar
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
Hell the glass tops dont weigh a whole lot anyways. I cant see the plastic ones offering any advantage over the glass ones
Old Aug 5, 2003 | 05:41 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Without your t-tops on the car you are basically offering up a giant scoop to the passing air and slowing your ET by a bunch! Like the other guy said, it is like dragging a parachute behind you all the way down the track.
It is cool for cruising but just plain BAD for drag racing
Old Aug 5, 2003 | 03:23 PM
CaddiBird's Avatar
Car: 89 base 'Bird
Engine: 507ci Caddy
Transmission: BOP TH400
the main point is at any legal drag racing track you must have #1 all windows rolled up(aka t-tops on) #2 seat belt #3 secured battery and seat and #4 properly working neutral start safety switch. thats the main things a track guy will complain at you about. ofcourse you wouldn't street race now would ya cause thats illegal
Old Aug 5, 2003 | 08:55 PM
MILT's Avatar
From my experiences at a road course event, convertibles or t-top cars were allowed to run w/ tops down or t-tops off only if they had a roll bar. Granted your aerodynamics are much better with them on, it sure makes for one hell of a ride with them off. Save your money and keep your glass tops...you'd probably pay as much as a set of power pulleys, which would give you more HP.
Oh, and just for the record: I LOVE my lexan tops (I'm probably the only one)
MILT
Old Aug 6, 2003 | 08:21 AM
Car: 83 Z28
With the T-tops off, they don't make you use arm restraints?
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
Amillionoh7
Sep 5, 2015 11:44 PM
