Replacement battery tray?
Old Dec 10, 2003 | 10:58 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Does anyone know of a company, or somewhere I can get a replacement battery tray from? Mine is quite corroded and rusted.
I know I will have to drill/cut my old one out, and weld in a new one.
Then I will have to get a correct size battery too
Old Dec 10, 2003 | 11:10 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
when i did mine on the 82, i just braced the underside of a piece of sheetmetal and used that.
*shrug*
Old Dec 10, 2003 | 11:18 AM
Dale's Avatar
Engine: 350 S-TPI
Wont work, the tab that holds it down is rotted away. Battery just flops around.
Old Dec 10, 2003 | 11:46 AM
pskel350's Avatar
i think classic industries has a replacement....im not home right now, so im not totally sure.
Old Dec 10, 2003 | 01:16 PM
Dr G's Avatar
Dale here are some links with info you may find useful. Links to companies and even a part number or two.
https://www.thirdgen.org/techbb2/sho...t=battery+tray
Battery Tray Replacement
Battery Tray
I need a battery tray
Have you considered relocating the battery to the trunk area instead?
Best of luck!
Old Dec 10, 2003 | 01:25 PM
Dale's Avatar
Engine: 350 S-TPI
Hey, just want the DR ordered
Sorry, chessy, but I had to say it. Thanks for the links :hail:
After hearing about all the venting I would have to do, to install the battery in the trunk, plus majorly longer wire, I prefure not to. I know its better for tire spin and weight transfer. My old s10 had the battery in the bed, and I was constanly having problems with the long wire.
Old Dec 10, 2003 | 02:10 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Just remenber the old welded in battery tray was part of the front fender support. So I would keep that in mine when thinking about a new one.
Old Dec 10, 2003 | 02:22 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
thats why i braced the metal undernieth when i welded mine in.
Derick15
Sep 17, 2016 05:28 PM
justin57
Aug 20, 2015 07:05 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
