Autometer tripple gauge A pillar pod owners - step inside
Car: '87 Z
Engine: 355 in the works
I got a tripple gauge A pillar pod from autometer, part # 12203, and I just wanted to see how many of you guys out there have one that doesn't fit for crap. The lowest gauge pod on mine is all the way against my dash pad... it's very irritating. I'm tempted to send it back and get a dual and single pod to put together.
Just like some input to see if I'm the only one, thanks.
Make sure you got the one for a hardtop if yours is and not the one for a TTop car. I ordered one for a hardtop car and got one for a t-top car and didn't know it until Kandied91Z helped me. It didn't want to slide down the A-Pillar and sit flush at the top. So I ended up having to cut the top off of it. I would of had a ton of pictures but my compter crashed a month or so ago. Let me know if I can help you out.
Sean
Sean
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I have about 1" of clearance between the lower pod and the dashpad using a single and a double. I can assure you that it doesn't look bad if you have to go that route.
I think it would be fairly obvious if you have the hardtop version - it won't wrap around the ttop headliner like the ttop panel does. I hope you'e got the right part and even more I hope the tripple pillar is correctly molded.
Did you get gages for the thing yet? Haha..maybe for Christmas you did!
Car: '87 Z
I'm pretty positive I have the right part number for Ttops, and it's just plain that autometer made the gauge pods down too low... if they were all moved up an inch it'd fit awesome, but the lowest pod hits the dash pad. I'm thinking I'm just gonna put it in anyway.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i got the triple gage pod for ttop cars and yes it is a very tight fit. its only a pain to get the a piller back in but other then that its all good, i got my a/f gauge, trans temp, & vacume, in the pods.
Car: 85 Trans Am
Engine: 305 Carb
Got the triple pod for a t-top car as well. Have not fully installed it yet, but test fitting it before I put the car up for the winter, the bottom pod did rest on the top of the dash pad making for a tight fit.
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Got a question on the piller gauge pod.I have Sunpro 2 inch gauges(style line series).Will these gauges fit in the piller pod ok.
Car: 87 GTA/88 Iroc
Engine: L98/LO3
Transmission: 700r4's
i was wondering if they fit so close to the dash pad on fbodys too, because i have the tripple for my eclipse and it hits the dash too. Im definatly going with a double after seeing how close that is.
Car: '87 Z
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mine fits pretty darn good,
When I had the stock dash, the bottom pod dented teh dash pad like the pictures posted above,
ambainb
Apr 25, 2016 09:21 PM
