Roll On Primer
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
Roll On Primer
I just heard of roll on primer, is this is as good as it coming from a gun?
Anyone ever used it?
And where and what brand is the best?
Thanks yall
-Jensen
Thanks yall
-Jensen
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Hell no, not even close, dont even mess with it, and dont use rattle can junk, get urself a gallon of 2k100 primer, thats the good **** i used on my camaro, its about 80 buck for the primer with activator
Okay thanks guys.
I'd still like to hear others opinon on it too.
If it's made by PPG you would think it be good stuff.
Car: 87 IROC Z28
How mcuh proof do you need, i work at a body shop, this is what i do for a living, dont mess with it, but you dont have to take my word for it, do it, go for it, why not make 3 times as much work, maybe you like to work.
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
How many body shops do you know that use anything other than air compressor sprayed on stuff? The roll on primer doesnt sound like it would work too good but im not speaking from exp either. Good luck.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Sure would be fun to watch a guy jamb something out with a paint brush though
Maybe they sell textured rollers too so you can match the texture of your interior walls at home to your ride..bling bling
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well guys,
Believe it or not, but there is a special type primer that is rolled on and it smooths out really well. It is used on boats in areas where spray painting would have an impact on the enviroment. It is also rather expensive to boot!!!!!!!
The Trickster!!!!!!!!!
Car: 1990 Formula
Transmission: WC T5
Well Gentlemen, I have rolled on primer on many occasions, with great success. Actually, it was surfacer, use to be called fill and sand back in the laquer era.
In areas where I was trying to get a dead flat pannel and I was sanding 80-90% of it off anyway, I have rolled it on, a heck of a lot more convient than having to clean a gun and mask off an area. However, the texture was rough before sanding, I didn't care, I was going to sand it down with 180 anyway.
I would never try this for a non sanded area. After I was happy that the panel was flat I then sprayed the sealer primer and painted.
I have seen plenty of professionals use roll on primer so it is definitly not crap. It all depends on what you want to do and how good you are at it. There is a link somewhere in one of the paint your own car threads that goes through a step by step for preping, repairing dents, and painting a 3rd gen. The link is from a shop that does frame off restorations of cars. I think they know what they are doing. There is more than one right way to paint a car, each method has its pros and cons, you just have to deside what is right for you.
darwinprice
17
Oct 11, 2015 11:51 PM
