Is there anyway to pretty up the HVAC controls?
Old Mar 3, 2004 | 12:52 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I mean, i know you can scan a different color and make them white but im talking about overhauling them. I see a lot of good looking interiors on this board but always the ugly HVAC controls. Is there anyway to make them look a bit more modern?
Old Mar 3, 2004 | 01:30 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I've been tossing the idea of swaping it out with a newer gm hvac controls. I got to start diging up some wire diagrams and stuff to see if it is possible.
Old Mar 5, 2004 | 01:07 AM
3rdGenSS's Avatar
Car: 91Z28, 94 Silverado, 99Z28
Engine: 350 TPI, 350 TBI, LS1
Transmission: 700R4, 4L60E, 6-speed
Axle/Gears: 3.42, 3.42, 3.42
you can use the 93 and up hvac controls from the camaro or firebird.. you would have to mod the opening to make it fit..also the wireing and vac lines are not that hard.. the blower wires are the same..hot/cold hard line needs to be modded alitte to make it work and the vac line colors are a bit different but doable.. most everyone doing the 4th interior have done it and alot of info is on the boards..i am putting the controls in my 91Z soon as i get them in ill let ya know...
Old Mar 5, 2004 | 01:42 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Attached Thumbnails Is there anyway to pretty up the HVAC controls?-interior.jpg
Old Mar 5, 2004 | 03:54 AM
Kandied91z's Avatar
if anyone has a write up about swapping 4thgen controls or even a newer style setup please let me know as well. i want to extend mine to relocate it off of the dash and this would help me greatly.
Old Mar 5, 2004 | 11:22 AM
deadbird's Avatar
Engine: TPI 305/ v6
I would question the 93 up controlsfitting even with modding the opening. In searching, they were just way to wide to fit. The one I have from a corsica (or one of those) doesn't even fit all that well and modding is reqired to get it in and you have to make new mounts. I had to remove the hot/cold because the cosica's had the servo controlled hot/cold selector which is to large to adapt on a 3rdgen and have the underdash cover fit. I adapted a 4thgen hot/cold selector and found they work opposite the 3rdgen slide. I pulled the cable from a mid 90's s-10 which is about double the 3rdgen cable and mounted it to the opposite side of the selector door to fix the problem.
The vac diverter will work but, not properly. I haven't gooten much further than that since the car has taken a back burner to more important things for the moment.
Old Mar 5, 2004 | 12:44 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Originally posted by deadbird
Thsoe in Deadbird's look like 91-96 BERETTA HVAC controls. Is this true? Are they a directly bolt in?
Old Mar 6, 2004 | 10:53 PM
deadbird's Avatar
Engine: TPI 305/ v6
Don't get your hopes up.. if you read my 2nd post.. it's not a direct bolt in at all and IMO... hardly work the work just for a minor, no one but you will really appreciate, upgrade.
Old Mar 22, 2004 | 03:52 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I never tried anything like this, but I have an idea that someone may be interested in. If you want to use a larger HVAC control like Deadbird did and you have an aftermarket radio (smaller than the stock one), you can fabricate a new radio/hvac bezel with a smaller radio opening and a larger HVAC opening.
83 Crossfire TA
Jan 3, 2016 01:26 PM
777Shock777
Oct 29, 2015 04:30 PM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
