my b&m pro stick install
Old Mar 12, 2004 | 09:03 PM
jon_volk's Avatar
ditched the stock piece of crap for a b&m pro stick (ive had one ratchet shifter and ill never buy one again..gated all the way).
Biggest pain in the *** was routing the damn cable. Cut the stock shifter mechanism off its base and welded the pro stick base to the stock unit. Now its a direct bolt in. Also made an aluminum panel for it.
Old Mar 12, 2004 | 09:04 PM
jon_volk's Avatar
b&m being fitted before welding to stock base.
Old Mar 12, 2004 | 09:43 PM
nolanr0413's Avatar
Car: Trans am
nice, it looks like it needs something though. I think maybe an indicator sticker. but good job.
Old Mar 12, 2004 | 11:48 PM
bes217's Avatar
It needs some sort of boot to cover the hole as well. But, all in due time.
Old Mar 13, 2004 | 09:07 AM
jon_volk's Avatar
ill be putting some type of indicate next to each respective gear once i find something that doesnt look out of place.
im not putting a boot on it b/c they i wont be able to access the reverse lock out lever which is just about flush with the level of the plate.
shifter is there to safely manual shift gears, not to look pretty. although it does look better than the stock heap imo
Old Mar 13, 2004 | 03:45 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Pretty nice job. Definately need some kind of indicator.
Old Mar 13, 2004 | 05:05 PM
BOTLFED's Avatar
I like it, I don't think it needs anything else...
Cheers,
Old Mar 13, 2004 | 05:40 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Cheers,
ditto it doesnt need a boot it looks fine now...
Old Mar 13, 2004 | 08:34 PM
V6camaroman's Avatar
very nice install man. i am getting the exact same shifter for my maro. you had to get the 4 speed shifter gate plate for the 700r4 right? thanks for giving me the extra infor on install.
Old Mar 13, 2004 | 08:46 PM
jon_volk's Avatar
yup, just had to get the 4 speed gate plate. Other than that it was a pretty easy install.
Old Mar 13, 2004 | 10:23 PM
Jose'sRedTA's Avatar
Car: 87' Red TA w/ 92k miles
for a boot to hide the inner portions of the console and to keep things from fallin in you could use some of that broom like material that they used in are our hatch pull down mechanisms to cover up the latch area...i don't know the technical name for it but that might look good there...cool install!
Old Sep 5, 2012 | 10:53 PM
Collin Eiten's Avatar
Re: my b&m pro stick install
How far from the front or back did you put the shifter on the plate?
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
LT1Formula
Aug 20, 2015 09:36 PM
sonu1975
Aug 11, 2015 08:38 AM
rsrmoore
Aug 7, 2015 08:44 PM
