TA Front End
Old Mar 22, 2004 | 07:09 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
TA Front End
ok I am a camaro owner but my Brother has a 1984 Trans Am and he wants the front end to look like this, What year and model do I need to order also will it work with 1984 Hood and Fenders or do they need swaped.
Old Mar 22, 2004 | 07:33 PM
MNformula350's Avatar
85-90 had that front end, it should bolt right up to the fenders but you will probably have to drill new holes for the GFX pieces that go with that nose.
Old Mar 24, 2004 | 10:04 PM
trans_am_ta_84's Avatar
Car: 89 trans am
Engine: 355
exactly.. you'll definitely have to drill some holes in the fenders and ground effects to get them to fit right because the holes don't like up. i put an 84 fender on my 89 and needed to do some drilling.
Old Mar 25, 2004 | 10:28 AM
nolanr0413's Avatar
Car: Trans am
i thought he has to switch the honey comb suppots too, i thought they were different from 82-84, 85-90 ,91-92.
Old Mar 25, 2004 | 02:48 PM
ya know now that you mention it i had to swap the bumper with the honeycomb when i swapped my nose for a 84 style from the 90 cause the 90's didn't let the 84 nose fit right. that's all right though the bumper i ended up using was aluminum and lighter than the stock one by half
Old Mar 26, 2004 | 11:04 PM
BlargMaster's Avatar
Car: 1983 Firebird SE
Engine: 5.0L V8
Transmission: TH700R4
I am just about to pull this swap on my 1983 Firebird SE. I have been waiting 3 montsh for my front bumper, and it finally came in today. I am going with the '92 camaro sideskirts. The bumpers will bolt right on, but you will have to drill holes for the side and quarter pannel ground effect peices...
Hope to have everything installed within the month. I'll post pictures with the process as I go along...
Old Mar 27, 2004 | 10:46 PM
Faded's Avatar
Car: '91 Firebird
i think you need to replace the support behind the cover too.
Old Mar 29, 2004 | 10:55 AM
Engine: 5.0L V8
Someone please correct me if Im wrong, but I believe you only need to replace the support if you are swapping to a '91-'92 style front bumpers. It is the bumper support that holds and mounts the fog lights for the slots on those bumpers...
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
