Cheap Headlight Assembly
Old Apr 24, 2004 | 01:06 PM
dru_pe's Avatar
Car: 1991 Firebird
Engine: V6 3.1
Transmission: Automatic
well im cheap and damn headlight assemblys are not, heh, i am looking for a way to fabricate one of my own, a simple one, prob a permenent one, dontsnt meed to move up and down, i have full access to a sheet metal fabrication shop, with break presses, lasers and everything else that comes with a sheet metal shop, i know how to run all these machines what i was wondering was if ne one had any ideas as to design, i have a few ideas but im sure someone can come up with something good, thanks for the help, heres a pic of my current setup, pretty isnt it
Old Apr 24, 2004 | 02:14 PM
dsaint1347's Avatar
I like that look.
Old Apr 24, 2004 | 07:55 PM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
dude that is the type of **** reservation racers have:nono:
Old Apr 24, 2004 | 11:23 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
I can see this thread going south in a hurry. Try to keep this on topic or I will close it. Thanks.
Old Apr 24, 2004 | 11:33 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
You might be cheap, but some things you have to do the right way. You can't really fabricate something like that and expect it to come out right.
You'd have to be better than 99% of the metal workers out there to get that to come out as good as the original. Best thing to do is breakdown, and go to the junkyard and get the parts you need to make that right.
That's my advice anyway.
Old Apr 24, 2004 | 11:51 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I'm not sure what you consider your time worth, but I just replaced my headlight assembly, including the halogen headlight, bracketry, door and the actuator motor for $40. Junkyard and save your time for making horsepower
Troy
So Cal
Old Apr 25, 2004 | 05:48 AM
dru_pe's Avatar
Car: 1991 Firebird
Engine: V6 3.1
well im not syaing it needs to look good, just a little better then a bungee holding it down, im sure eventually i will invest more time and money into my car, just at the moment im a little strapped for cash, just looking for a quick fix
Old Apr 25, 2004 | 03:27 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Check ebay. I can't begin to imagine the damage that could occure if water got in there. You could probably score a good set of headlight assemblies for a good price on ebay.
Old Apr 25, 2004 | 11:57 PM
Adrenaline's Avatar
Car: 92 Camaro RS
Heres an idea another guy on the site did to his bird...
https://www.thirdgen.org/techbb2/sho...hreadid=234297
Old Apr 26, 2004 | 12:25 AM
Sir Speed A Lot's Avatar
Car: 1984 Trans Am
Engine: 305 LG4 :(
Transmission: 700r4 :(
fellow thirdgenner. if i looked at your car and saw a fugging bungee holding the headlight down id like... kick your car or break the headlight off or something but DAMN kid that looks like HELL...
go to a pick and pull yard and spend the 20 dollars and do it right...
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Elephantismo
Interior Parts Wanted
Sep 24, 2015 05:15 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
