Updated engine pics
Old May 17, 2004 | 11:11 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Updated engine pics
Took some shots of my engine bay this past weekend.. its been through a lot since it was last seen.
It was..
It is..
(sorry these pics arent resized, im not hosting them)
Lemme know what ya think.
Old May 17, 2004 | 11:23 PM
Car: 1987 IROC Z
all of this is after ...
Accell/lingenfelter runners,
ported n Polished plenum
Edelbrock manifold,
Lingenfelter cam (.350, 218, 114)
Aluminum radiator
AC delete
rebuilt heads 1.5 roller rockers (should have put 1.6 but didn't want to waste the money on these cast iron heads)
3 angle valve job on the heads
B&M 2400 TC
Engine rebuiled (bored over 40)
custom battery tray in the rear,
Taylor wires (just had yellow at the time, didn't find red)
MSD 6AL,
Accell coil
AFPR
holley 255LPH fuel pump
Braided fuel lines (others popped after installing the AFPR and running 100 PSI through them)
SLP CAI
exhaust cutouts...
Flowmaster cat back american thunder series exhaust
24LB Cobra injectors (blasphemy I know... but they are from a ford)
other things I have since forgotten about the tranny..
Gears and an aluminium drive shaft are next on the menu...
Old May 17, 2004 | 11:45 PM
jay92,85,79's Avatar
Car: 85z28,
Looks sweet man can't wait till my z looks like that.
Old May 18, 2004 | 07:37 AM
nolanr0413's Avatar
Car: Trans am
have u been to the track with it.
Old May 18, 2004 | 08:02 PM
MdFormula350's Avatar
nice improvement!
Old May 18, 2004 | 08:42 PM
Car: 1987 IROC Z
sadly no.. not yet.. It runs but shifts from 1st to 2nd way to early. I've got some trouble shooting to do... I runs pretty hard either way though when I shift it manually with the B&M, I just wish that I could control its shift from 1st to 2nd (without a manual valve body).
Old May 19, 2004 | 12:01 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
I had the same problem with early 1-2 shifts mine was tv cable adjustment. If you removed it when you did everything that was done and did not re-adjust you need to.
Old May 20, 2004 | 09:41 AM
Car: 1987 IROC Z
I saw the thread once that described that.. do you know which it was ?
Old May 20, 2004 | 10:11 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Looks nice, but I think you need to finish painting your strut tower brace...
Old May 20, 2004 | 10:12 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
well there are alot of post on it here is one that describes how to do a search for cable adjustment and you will get much more.
https://www.thirdgen.org/techbb2/sho...ble+adjustment
Old May 21, 2004 | 09:36 AM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
I got stuck between having it black and having it red. I think instead I will have it chromed. I think that would look nice for the STB.
Old May 22, 2004 | 12:43 AM
bes217's Avatar
I like the black valve covers. They are not gaudy like chrome covers, but they look very clean. They kind of set some of the other items in the engine bay off.
Old May 22, 2004 | 01:40 AM
Damn, sorry I guess I forgot to log out at your place Randy. You posted as me. Sorry.
Old May 24, 2004 | 11:36 AM
I also bought the matching timing chain cover... doesn't matter though as you cant see it. Almost wish there was a power steering relocate option. I didn't think about the timing chain being covered when I had it put on... Doh
Old May 24, 2004 | 12:12 PM
CaysE's Avatar
There's nothing like a well-routed set of nice spark plug wires.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Fast355
Dec 2, 2016 06:33 PM
project89
Sep 24, 2015 06:38 AM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
