The Saturn Gas Cap Door Switch
Old May 26, 2004 | 12:14 AM
KBeez's Avatar
Car: 88 Camaro S/C
Transmission: 700-R4
Okay, somehow my search couldn't find any of the old topics, but I had a few questions on putting a flush mount popping gas cap in my third gen.
1. What model/year am I looking for here?
2. What all parts do I need, like just the gas cap part, or the hinges as well, and I know I'll need the cable and release switch.
3. What tools will I need to bring to the yard? (not a huge deal but I'd hate to get there and not have everything I need. doh.)
thanks for any help
Old Aug 10, 2004 | 05:00 PM
KBeez's Avatar
Car: 88 Camaro S/C
bumping my old topic, forgot about hehe but I still want to do it. any help here?
Old Aug 10, 2004 | 09:40 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
i'm interested in doing this also. Sorry i don't have any info to contribute, but next trip to the yard I'll look for a cap that would fit and see how tough it looks to adapt to a 3rd gen.
Old Aug 10, 2004 | 09:50 PM
KBeez's Avatar
Car: 88 Camaro S/C
Well this is the info I've gathered, this isn't 100% so I'm looking for confirmation and any tips, etc.
You need the cap, the latch, the hing spring, and the cable pull release.
Not sure but I think it's an early 90 model of the sl2 is one that works, among others.
It does work, and it's the correct size already.
The cable can be placed next to the driver seat like any other car with your own work.
That's a start, I guess I'll just hit the yards as I guess if it's the right diameter, there both gm, so it should work. And I don't think they differed that much as far as the gas caps are concerned in the round-capped saturns.
Old Aug 15, 2004 | 12:35 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Thats the same saturn model i took my parts from.Although the gas door is a little smaller in diameter.You will need the levers,cable,latch release,gas door.I used my original gas door & grafted the (striker & spring)from the saturn gas door onto my original gas door.I also took the flat spring from the saturn gas door & adapted it to my original in the same fashion as it was on the saturn gas door.The release lever was mounted next to my driver seat.Although i had to lengthen it a bit using the trunk lever from the saturn(gas/trunk levers are a 1 piece design).From start to finish it took me about 4 hours.Did this over a year ago & it still works great.Just look for the SL2 model(but i believe ALL saturns use the same set-up though).
Old Aug 15, 2004 | 01:33 AM
KBeez's Avatar
Car: 88 Camaro S/C
Hey 84 1le, when you say you just used the parts and grafted them on your gas cap, you're saying you still have the stock gas cap door on the car still? I did want to do the flip switch for security reasons, but I also wanted a flush mount gas door. Maybe I could use the stock door cap, cut out the finger hole and have a body shop redo it?
eh
Old Aug 15, 2004 | 02:30 AM
camaraman30's Avatar
Car: 83 z28 with 89 ground effects and complete dash.
Engine: 305 h.o.
Transmission: borg warner t-5 manual
I want to see pics of this, sounds interesting. I've been toying with the idea of the racing gas door but it seems like i'd be confused with someone who was going to r i c e a third gen. the stock door needs help for sure.
Old Aug 15, 2004 | 10:27 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
eh
Yes i still have the stock gas door.I also cut off the finger(hole)& cut a piece of balsa wood to fill in the (hole)(this was done way before the saturn mod).I didnt want to redo this.So when i used the saturn parts.I just cut the portion of the saturn gas door where the striker is & grafted it to my original door( i used 3 small rivets to hold it to the original gas door).This worked out for the better,because it gave the striker more reach to the latch release.Ill post pics later on today if youd like....
Old Aug 16, 2004 | 09:23 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
well here are some pics.1st ,gas door.The semi circular thing on top is for the gas cap.Took that from some GM car,cant remember which one.You also see 2 of the rivets that hold the saturn striker w/ part of the gas door to my original.
Old Aug 16, 2004 | 09:29 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
heres the door closed
Old Aug 16, 2004 | 09:34 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
& the latch.Some trimming was needed to clear 1 of the 3 screws that hold the splash gaurd to the Qtr.panel.That screw was also moved to the edge or the latch would've sat on top of it.
Old Aug 16, 2004 | 09:36 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Heres the release lever
Old Aug 17, 2004 | 01:26 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
very very nice :-). That's exactly the look and functionality I'm going for. I'm going to search around and see if i can find a gas cap the correct size with a release mechanism already on it to save some time on modifying the original cap.
Old Aug 17, 2004 | 10:43 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
wow.. not bad.. not bad at all.. I like it.. Umm.. .Save this idea for later. Thanks
Old Aug 17, 2004 | 10:59 PM
twysted87's Avatar
Car: 87 gta 89 ta
Engine: 5.0 5.7
Transmission: 700r4 x2
good job , definitely a *** idea:hail:
Old Aug 18, 2004 | 12:54 AM
KBeez's Avatar
Car: 88 Camaro S/C
Thanks for the pics
And so is balsa wood the best way to remove the thumbhole? I'd figure some kind of fiberglass or something?
Old Aug 18, 2004 | 06:50 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks for the pics
Almost any type of material will do.As long as its not too thick.Balsa was just what i had around at the time.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
BlackTopKing
Aug 19, 2015 12:13 PM
