warped...
Old Jun 15, 2004 | 05:45 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
warped...
Ok, first off, it was hot out and I was anxious to shave my handles. So.. I took out the lock and handles in about a total of 5min. (made me realize how full proof our locks were. lol ) So, I cut out sheetmetal and welded it in. I didnt butt weld either, just tack welded it.(one side, other side, ect for it doesnt warp) But Viola, it warped! Any suggestions on what I should do, the warps are not deep at all. They are very minor and i just want some input. Just don;t come in here calling me a dumbass because I know I screwed up. Positive comments please.
Old Jun 16, 2004 | 11:14 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
no replies, i guess everyone has all bad comments
Old Jun 16, 2004 | 11:33 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
your going to be using body filler anyway right? Just glaze a smooth surface of body filler over it...unless you want to cut all the metal out and re-do it..which I wouldn't wanna do...
Old Jun 16, 2004 | 08:26 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Can you knock down the high spots with a hammer and dolly or will that not help at all?
Old Jun 16, 2004 | 08:39 PM
87F383's Avatar
Car: 87 Formula 350
Engine: LS1 in Progress
Axle/Gears: 3.70 9 bolt
I'm no expert... but, I would either try to hammer to the highspots or take a grinder (depending if you have enough material thinkness to do so w/o going through it ) and take him down and use body filler to smooth it out. Or cut it out and start over.
Old Jun 16, 2004 | 09:28 PM
nolanr0413's Avatar
Car: Trans am
id say go with the bondo , if you use it right you will never have any problems with it. I mean do a few light coats. The stuff dries in about 3 minutes , so it wont take all do to make it smooth. you just gotta remember when u use bondo that you gotta do it in moderation. I think thats probably the easiest way to do it. Plus you need to use it to make it smooth anyway . Do you have a pic of how much it has warped. If the spots that need to be filled are big u could use tiger hair first, and then the bondo.
Old Jun 16, 2004 | 10:31 PM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
im no pro either but id do the hammer/dolly first and if that isnt right then it should be at least better and you can use a filler to get the fine spots finished.
Old Jun 16, 2004 | 10:39 PM
85silverz28's Avatar
Car: 1988 iroc z
Engine: 5.7 liter
Axle/Gears: 2.77
i took my time welding mine shut and still warped the metal...doors are kinda thin metal...dont take much...i just muded mine. If u do it right ull never see it
58mark
Sep 10, 2011 12:14 AM
dj haf
Oct 26, 2004 11:18 PM
BlargMaster
Feb 9, 2004 09:32 PM
tj78_
Sep 13, 2003 07:59 PM
