need to put more gauges in...where to put them?
Old Jul 26, 2004 | 05:49 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
alright guys, i need to put an air/fuel ratio guage and a vacuum/boost gauge. where should i put them and have it look like a good install? i would like to keep my stock cluster intact if possible. here's a pic to show where i am at right now...
Attached Thumbnails need to put more gauges in...where to put them?-interior-fire-extinguisher.jpg
Old Jul 26, 2004 | 05:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
This wouldn't work so well with the the tach where it is now though.
<img src="http://members.shaw.ca/crussel/camaro5.jpg">
Old Jul 26, 2004 | 05:54 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
why not in the ashtray or in the vent or on the door panel ledge
Old Jul 26, 2004 | 06:00 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
depends if you don;t need to loook at em al the time i would go with the center console where the window switched go, or hanging on the undersise of the dash next to the radios like in front of the passenger but angled to driver. but you may need to fab up something to close the back so it looks clean.
Old Jul 26, 2004 | 06:54 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I'd go with the ashtry if I were you.
Old Jul 26, 2004 | 07:58 PM
5SIZ's Avatar
Car: 1987 IROC-Z
ashtray...definatly the ashtray.
Old Jul 26, 2004 | 10:56 PM
Conman's Avatar
Car: 1987 Friebird Formula
Engine: 305 TPI (soon ot be 350TPI)((muwahahahhahaa)
Transmission: A broken 700R4
I've got the same stereo deck in my 87 Formula
Old Jul 26, 2004 | 11:05 PM
8IROC8's Avatar
Car: 88 IROC-Z
Engine: L98 350
Try the air conditioner vents...right about your tach. If you can figure out a way to make that work that would be a pretty good spot and you could see them well if you angled them.
Old Jul 27, 2004 | 03:25 AM
CrazyHawaiian's Avatar
Car: too many ...
If you were willing to move the Tach then you could run the three guages under the A/C vents like my 91 Z (pic here). Maybe disassemble the cluster, remove the stock Tach, and install the aftermarket one in the same space?
Old Jul 27, 2004 | 09:39 AM
mw66nova's Avatar
Engine: 7.0L
well, i don't have a stock tach, iv'e got the cluster with the big gas gauge. i guess i really don't need to look at them all the time. i thought about in the ashtray, i had my water temp and voltage gauges there for a while, but then i put it back to stock. i even have the angle rings to put them there, and the piece of aluminum that i used to fix them in place. putting them in the air vents would require modification to the vents themselves, the gauges are just too big in diameter. anyone got pics of clean installs of gauges in unique places. a non clean install is not an option.
Old Jul 27, 2004 | 09:44 AM
mw66nova's Avatar
Engine: 7.0L
here is an old setup in my old car, it required extensive modification to work though, i would like to avoid this as i currently have switches in the place of the gauges in this pic.
Attached Thumbnails need to put more gauges in...where to put them?-interior4.jpg
Old Sep 16, 2004 | 08:46 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Damn that looks clean! What happened to the car?
Old Sep 16, 2004 | 04:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
My oil pressure guage.
Old Sep 16, 2004 | 06:32 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Hey! That's my steering wheel!
(no not using this as an excuse to show my new halos off )
Old Sep 16, 2004 | 07:13 PM
bbigbrn612's Avatar
Car: 1984 z28
right on the steering wheel? like dead center.... dont you have enough? are you addicted to gauges like crack?! lol jk
Old Sep 17, 2004 | 06:58 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
https://www.thirdgen.org/techbb2/sho...ghlight=gauges
Read more here also
http://members.optushome.com.au/iroc...lie/inter.html
BRoss99
Aug 10, 2025 05:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
86IROC112
Aug 17, 2015 02:00 PM
