were the HELL can i find a non lift off 6 inch cowl hood that is actually decent?
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
there is no way you need a 6 inch cowl, it would look fing rediculous imo. but since that didn't answer your question may i ask what your setup is gonna be that would need a half foot of cowl hood? cus i've seen some pretty badass setups,supercharged dual carb and everything and a 3- 4 inch cowl usually does the trick
Here's one:
Don't know what the quality is but they have up to a 9" cowl.
Car: 89 camaro RS and 90 camaro IROC Z
Engine: 2.8MPFI V-6 and 350TPI 5.7 liter V
i may be wrong but will a 6 inch induction even open up all the way? isnt that why they are lift off?
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
dont let anyone tell you a 6" will look horrible. i had to have one for my setup. the carb sat 1.5" above the hood and i have a 4" tall cleaner. i am also thinking of adding a small shot of nitrous later down the road with a plate system so it will be tight with a 6". i just put a scoop on and i think it looks friggin sweet.
Car: 1986 camaro
Engine: 383 sbc
i got it from a guy on ebay called grapeaperacing i believe. it was the best quality of scoop i have seen. just so you know, it is not a hood its a cowl scoop. it looks freaking awesome. i got the shorter one in length when i should have got the longer one but it looks sweet. all for 40$ shipped.
Car: 1986 camaro
Engine: 383 sbc
it does somewhat obstruct your view from the seat but not bad at all. the thing is you cant see the passenger hood in the from but you can see around it.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
hate to point out the obvious, but a 6" cowl would hit the windshield before the hood opens enough to work on it.
thats why they're all lift offs.
Car: sc
Engine: 383carbed
Transmission: th400
Axle/Gears: 4.11 12 bolt
Car: 1986 camaro
Engine: 383 sbc
mine doesnt hit the windsheild.?
then again it is a scoop instead of a hood i guess.
then again it is a scoop instead of a hood i guess. Thread
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
