Speedo Head Question
Old Sep 26, 2004 | 01:16 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Hell all
I have is a '89 Firebird 305, the transmission and rear end have been calibrated for my stock Speedo which is 120 Mph, if I put in the 140 Speedo will I reading the correct speed? if not what will I have to do to correct it. Or can I just buy the 140 Mph gague overlays and I will be ok? Any information will be greatly appreciated.
Brad
Old Sep 26, 2004 | 04:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No other changes are necessary to make the 145 mph head work other than swapping the head itself.
Old Sep 26, 2004 | 08:17 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
if I dont replace my 120 MPH speedo head and buy the 140 MPH overlays, will this work? or must I have the 140 MPH speedo installed with the 140 overlays to make everything work good?
Old Sep 26, 2004 | 11:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As I understand it, speedometers are geared for their specific speed so an overlay with a different 'face' would not read correctly.
JamesC
Old Sep 26, 2004 | 12:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The speedometer doesn't look at it's face to figure out how high it's supposed to read.
Old Sep 26, 2004 | 01:36 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
So this chart wouldn't apply to making the speedo work accurately?
Old Sep 26, 2004 | 03:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not at all. He already has the correct speedometer gears.
Old Sep 26, 2004 | 06:01 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The gearing might work if he figured ut the percentage of change needed to read properly.
With the Firebird electric speedo, he'll likely have to swap over the circuit board attached to the head as well.
Old Sep 26, 2004 | 06:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, there is no gearing change required. The circuitry is part of the head.
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
