Firebird built from scratch
Old Oct 5, 2004 | 01:57 PM
joshwilson3's Avatar
Old Oct 5, 2004 | 03:49 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
If by "from scratch" you mean Can you build a Firebird out of all repro parts without ever using a real car? then no. There are parts that are not reproduced, like the firewall, the trans tunnel, etc. Plus, you need a VIN tag to register it.
Building the shell of the car out of pieces is really futile since you can pick up a thirdgen shell for almost nothing. Believe me, you'll put enough money in drivetrain, suspension, interior and paint. You don't need the extra expense of building a shell from scratch.
Just my $.02
Old Oct 5, 2004 | 04:39 PM
ADV1's Avatar
Hey dorko... you don't need a VIN... how do you think kit car guys get away with it???
Otherwise your correct on all points...
By the way Firebird...
I Rule!!!
Old Oct 5, 2004 | 04:51 PM
Kandied91z's Avatar
sure you can build one from scratch, if you have the knowledge and resources anything can be done.
Old Oct 5, 2004 | 05:07 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
They re-use the VIN from the Fiero they built the kit on ?
Then fill out a "Body Type Clarification/Body Type Change Affidavit" so the title/registration will reflect the changes/mods.
Otherwise, depending on state laws, you have to fill out an application for Special Identification Number for motor vehicles.
It does however (in Indiana), have to have and id # to be titled, registered and licensed. Just my opinon though....
Old Oct 5, 2004 | 08:32 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Well you will soon be able to build a 69 camaro from scratch, read the latest edition of hod rod, wonder if they will do a thirdgen..............mmmmmm probably not
Old Oct 5, 2004 | 10:36 PM
John in AZ's Avatar
Car: 92 Firebird soon to have 88 gta bumpers & ground FX on it. If anyone needs toh 92 style stuff let me know I have all of it except for a couple of small parts I just hate that style.
Engine: 5.0 TBI
To bad you are not closer to me. i wil have a shell that would be worth restoring that I would sell cheap. It is a 89 GTA was a 5.7 with t-tops. I remember asking the pontiac dealer back then about them and was told they were not usually made because of the extra torque? could be BS though.
John
Old Oct 5, 2004 | 11:30 PM
Avenger007's Avatar
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
Hey firebird 383 what was the process like putting on the new 91 front end? Did you just need the plastic bumper itself or the whole reinforment rubber and everything. Also do my 88 headlights fit with it. I found a rear bumper from a guy thats from a Trans Am and he says it was the same design from 84-92. Is that true?
Old Oct 6, 2004 | 02:18 PM
Old Oct 6, 2004 | 07:20 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Supposedly they used better sealants and stuff on the 92's, in an effort to make the body more rigid. Don't know if I'm right though, I think it's even listed in the tech section under productin history. Something like that...
Old Oct 7, 2004 | 02:13 PM
Old Oct 7, 2004 | 02:17 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
You can re-seal the seams, if that's what you're talking about, If you really want to do some work, I read somewhere you can weld the seams. I'll bet that will stiffin things up a bit.
Old Oct 8, 2004 | 04:31 PM
GarageToys's Avatar
Hey dorko... you don't need a VIN... how do you think kit car guys get away with it??? Otherwise your correct on all points...
Maybe in Nebraska. In IL you have to have a VIN tag and a title to register the car. And Aric, I rule.
T/A rear bumpers came in 3 styles: 82-84, 85-90 and 91-92. The guy doesn't know what he's taking about. All the 91 conversion stuff is in this thread: 91-92 Bumper Conversion thread
PATRIOTIC1911
Northern Great Plains and Rocky Mountain
Oct 7, 2022 10:38 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
New2Chevy
Oct 4, 2015 11:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
