From Camaro to Firebird
Old Nov 23, 2004 | 01:01 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Hellooo all, been a few months since I posted here. Sold my Camaro... gas was killing me. somewhere around 7-10mpg is just brutal.
But this time I'm going with a Trans am, I think the front end is just a little sexier
So I still want a V8, but hopefully a stock 350 will still get some ok gas mileage.
First question is: with a good exhaust, and a mild cam. Am I gonna get a nice low rumble? Also is working on a Pontiac just about the same as working on a chevy? Trans Am some of them come with carb? or are they TBI/TPI?
Thanks everyone, nice to be back
Old Nov 23, 2004 | 01:18 PM
megaracerx's Avatar
if you get a t/a with an lg4 it will be carbed. what year T/a are you looking at? the 350's a are tpi...i'm pretty sure
Old Nov 23, 2004 | 01:24 PM
Daishi's Avatar
well i believe in 1991-1992 the front end changed, I dont like them. But I also dont want all the electronic dash stuff. I liked my chevy with the cable speedo. Is it 1990 that the dash changed. If so earlier than that, but newer than about 1985...
so i guess 85-89 I think... sound about right? So I could get a Trans Am with a 350 carbed? I believe....
Old Nov 23, 2004 | 01:33 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
There never was a carbed 350 available in a third gen at any time. The front end changed in '91 and '92 and I also think its hideous.
Don't know about the dash changing, but I know my '88 has a VSS speedometer. I'm pretty sure the '87s did as well, but I don't recall if the '86 model year had that.
Old Nov 23, 2004 | 01:34 PM
megaracerx's Avatar
you might hvae to go pre - 85 for a stock carbed 350...but you could always buy one with a swapped 350...
p.s i dont like the 91-91 t/a front end either..
Old Nov 23, 2004 | 01:43 PM
Daishi's Avatar
what about on the other end. Mild 305 with exhaust and cam, perhaps a few bolt ons. Something that I can get sound and mpg out of... I want to buy the newest I can without getting into too many electronics.
Old Nov 23, 2004 | 01:46 PM
Car: 1997 Corvette
There....NEVER....was a third gen with a "stock" carbed 350.
Also, all of the third gens had an ECM that at least controlled something. Though obviously some more than others..
Old Nov 23, 2004 | 01:58 PM
Daishi's Avatar
Anyone know when the speedo went from cable to vss?
Old Nov 23, 2004 | 02:04 PM
87Formula4bbl's Avatar
Car: '87 Formula
I think '87 was the first year for the VSS. Mine has VSS, it's an '87 Formula.
Old Nov 23, 2004 | 02:16 PM
Car: 1997 Corvette
I think it was '86, but as mentioned above, '87 definitely did.
Old Nov 23, 2004 | 02:24 PM
anymethod's Avatar
Car: 1986 Trans Am
Engine: carb 305 LG4
Transmission: TH700-R4
Try to find a G92 '89 LB9 (305 TPI) 5 speed. Nice rumble and only a tenth or two slower than the 350. 91-92 f-bird front ends aren't ugly, just not as good as 85-90...
~Matt
Old Nov 23, 2004 | 08:28 PM
megaracerx's Avatar
well then what did they use before tpi? or maybe they didnt have an option for a 350 before tpi?
Old Nov 23, 2004 | 09:14 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Dash changed three times in Firebirds.
82-84, 85-89, and 90-92.
Cable speedo was 82-85.
Old Nov 23, 2004 | 09:28 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The L98 was the only 350 3rd gen. Birds are no different than camaros since they are the same car with a different skin.
Old Nov 23, 2004 | 09:38 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
LG4 305 or L69 305 (HO), both Qjet cars. Not sure if the crossfire is worth adding....
Old Nov 24, 2004 | 09:39 AM
CDNMARO's Avatar
Car: 87 Camaro SC
Transmission: 5-Speed
Except for Canadian cars... I had an 85 SC with LG4 & no ECM. My Brother's 84 Berlie had no ECM, for the engine, either. Not sure what the digital dash used tho
Old Nov 24, 2004 | 09:55 AM
Incoming's Avatar
Car: 1986 Firebird T/A Streetracer
Engine: V8 350TPI
Transmission: Modified 700R4
mines 86 it has vss no cable here
Old Nov 24, 2004 | 10:23 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
I have an 87 with the digital dash,not accurate either.I also have a tpi 305 with a flowmaster american thunder cat back on it.It has a nice deep rumble and it gets loud when I hit it.
Old Nov 24, 2004 | 12:59 PM
nolanr0413's Avatar
Car: Trans am
my 85 trans am with tpi has a cable driven speedo and vss . 82-84 didnt have vss , i dont think , but 82-85 is cable . so 85 is the only one from 85-90 , that style with a cable driven speedo .
Old Nov 24, 2004 | 11:51 PM
sellmanb's Avatar
Car: '86 Berlinetta
get headers, high-flowing cat, and 3inch exhaust all the way back w/ muffler of your choosing and you will be "rumbly" any of the 350s will be fast enough to back it up atleast... I believe mid 14s were their 1/4 miles.
Since you want a good gas mileage car, TPI is probably the best way to go. If you dont want much electronic crap... too bad lol, welcome to the 21st century
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Linson
Aug 21, 2015 02:12 PM
antares57
Aug 6, 2015 07:47 AM
