rear view mirror
Old Dec 21, 2004 | 04:15 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
rear view mirror
would anybody recommend an adhesive to glue my rear view mirror button to my windshield. every single adhesive i have tried doesn't work for s@#$. i let it dry completly, put my mirror on, go down the road and hit a bump and my mirror ends up in my lap. ive tried quicktite, and just about every adhesive specifically made for rear view mirrors at autopart stores..........
Old Dec 21, 2004 | 05:02 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Found some stuff at the gas station that has a primer and a adhesive. That crap won't come off.
Old Dec 21, 2004 | 05:13 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
kinna sounds like all the stuff ive tried. you used it personally though?
Old Dec 21, 2004 | 08:44 PM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
there is some killer stuff that Napa sells. we used to use it at the body shop I used to work at. you couldn't pull one of them things off, let alone have it fall off. they sell it as "rearview mirror glue." Imagin that...
Old Dec 21, 2004 | 10:19 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
First things first you HAVE to to do clean the windshield and the mating surface on the mirror. My g-friends used to fall down every 3-4 months with that auto store mirror glue. I took rubbing alcohol and a blue paper shop towel (lint free) and cleaned the two areas really well. Then I took a little JB Weld quick set and put a bb or pellet sized dot on the back of the mirror mount and then taped that into the correct spot on the windshield with masking tape. Clean up the excess after you press it tight to the glass.
I let it set up over night and it has yet to fall back off (knocks on wood). It's been up there for 3 years now. Oh, did I mention she parks outside in the Arizona sun every day?
GL!
Old Dec 22, 2004 | 02:57 AM
Morley's Avatar
To get it to stick take 000steel wool with acetone and scrub the windshield good. Then wipe with clean lint free rags and acetone. Next soak the shoe in acetone while cleaning the windshield then scuff sand it with 320 and clean off again with acetone. Use the rear view mirror adhesive from the parts store with the little vile of activator/primer and the little white triangular tube of adhesive. Follow the directions then tape the shoe in place for a few hours then install mirror. It shouldn't fall down again.
Old Dec 22, 2004 | 09:41 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I use the special mirror glue they sell at AutoZone ($1.99). The guys are right, the secret is in prepping the surfaces well.
I've used this glue on three cars and none of the mirrors fell off so far. The good thing about this mirror glue is that it's set and ready to go in about half an hour (I know it from my experience).
Lou
Old Dec 24, 2004 | 11:09 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
a glass shop will usually put it back on for around 10 bucks and wont come off. it smells a lil stronger than the regular permetex or loctite brands.
Old Dec 24, 2004 | 11:22 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
clean it really well and use a gel type super glue... this stuff works soooo good i glued mine thinking i would have a few sec's to move it to the exact place and it froze in place almost instantly and i tried to take it of with some plyers cause i just put it on and it cracked my windsheild......... i work at a dealership and i use this on ever one that falls... just glue it and let it sit for a day then put on the mirror
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Apr 30, 2019 12:14 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
