COMPLETE floppy column article in Camaro mag!
Old Feb 20, 2005 | 07:07 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
That's right! Don't know if anyone has picked this one up yet, but DO IT!
Camaro Performers magazine, Feb 2005. There are many articles in there, and one of them is a step by step (each with a picture) on how to fix the floppy tilt column!
Figured I'd throw that out there.
Old Feb 20, 2005 | 07:29 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I'm in the middle of fixing that now, such a PITA
Old Feb 20, 2005 | 07:47 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
whats the issue again? is it that the column will not stay firm when locked as in it has some wiggle room? or just all out no latching at all??
Old Feb 20, 2005 | 10:15 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
The wiggle problem. Or in my case, the wheel-doesn't-even-feel-attached problem, where the high beams and directionals don't work unless you hold the column up.
Old Feb 20, 2005 | 11:41 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
just make sure whatever you do dont break off a tilt steering pin remover screw inside the tilt stearing pin, those pins are hardend steel, i ground down 3 carbide steel bits trying to get that SOB outta there and never even scratched the damn thing. And i'd reccomend loc-titeing the loose screws in there so you dont have to go back in later, just remove them one at a time, and loc tite them when you put them back in.
-chillen
Old Feb 20, 2005 | 11:49 PM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
I better pick this issue up if I can find it, I have that problem too and its really annoying.
Old Feb 21, 2005 | 12:32 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
do it asap, it'll only get worse
Old Feb 21, 2005 | 12:58 AM
JDubya18's Avatar
Engine: 305 LB9
am I gonna have to take off my steering wheel to do it? Thatll give me an excuse to buy a new one lol
Old Feb 21, 2005 | 01:44 AM
CogsRS's Avatar
Car: 87 Monte Carlo SS
Transmission: 200 4R
I had that problem in my Iroc. It got REALLY bad, like when I would take tight turns the column would just lock and the car would die, almost got me into a couple accidents. That was NOT fun. Id suggest fixing it as soon as you can. I just swapped the whole column out though, only took me an hour and a half by myself, and a few busted knuckles but oh well. Would have taken half the time easily if I had an extra person around.
Old Feb 21, 2005 | 08:22 AM
LOL... you're gonna hafta take off alot more than just your steering wheel. But yes
Old Feb 21, 2005 | 10:53 AM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
We need a "tighten up your steering" tech article that covers everything from the steering wheel to the wheels.
Just about every 3rd gen I've driven has had floppy steering in one form or another.
Old Feb 21, 2005 | 11:50 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
A company by the name of LISLE make a tilt steering pivot pin remover # 19940.Though ive seen/heard of LISLE,dont know who sells them?
Old Feb 21, 2005 | 12:44 PM
Anybody have any ideas or suggestions as to how to get the pivot pin back into the column?
I was thinking C-clamp or something similar
Old Feb 21, 2005 | 12:53 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i have had to do this twice, i have it down to a frickin' science almost, can get it done in like 30 mins. it's such a pain in the butt though! mine was caused by never tilting the steering wheel up to get in and out and always hitting it while getting in/out. also, i used to drive around with no p/s pump with a p/s box. after i put the p/s pump back on and started tilting the wheel on a regular basis, it doesn't loosen up anymore.
Old Feb 21, 2005 | 01:06 PM
Ahem....
Old Feb 21, 2005 | 01:30 PM
mw66nova's Avatar
Engine: 7.0L
oh, sorry, i didn't have to take that pin out, so i don't know.
Old Feb 21, 2005 | 01:45 PM
How did you not have to??? Ughg this thing is pissing me off i cant even get the pin out
Old Feb 21, 2005 | 02:24 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally posted by srdynamics1
We need a "tighten up your steering" tech article...
https://www.thirdgen.org/newdesign/t...ngcolumn.shtml
...that covers everything from the steering wheel to the wheels
https://www.thirdgen.org/newdesign/tech/
Old Feb 21, 2005 | 03:23 PM
Update, i just went to Napa and ordered a steering pin remover tool, should be here tomorrow at 2:30 so we'll see how that works.
Old Feb 21, 2005 | 07:55 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
What brand & how much?
Old Feb 21, 2005 | 10:25 PM
Not sure of the brand and it was $22. The Napa guy looked it up in his catalogue.
Old Feb 22, 2005 | 07:06 PM
Sweet, everything is fixed, i will be finishing it up tomorrow night.
The pivot pin remover tool worked mint!
Old Feb 25, 2013 | 03:30 PM
stvenracer's Avatar
Car: 1984 Z-28
Engine: chevy create 5.7 350
Transmission: 700-R4
Re: COMPLETE floppy column article in Camaro mag!
so i also have a problem.. i took off my stering wheel and the locking plate to replace my turn signal switch and lever and now that im done and out everything together the steering shaft or whatever it might be calle is loose like just flopping around and it never use to do that dose anyone have any ideas what might be wrong or if i didnt put it back together right?
Old Feb 25, 2013 | 07:18 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Need to go back into the column and make sure the upper bearing support isn't either missing or not seated properly. It's the gold-colored ring that goes under the lock plate spring. It should be pushed as far as it will go into the upper shaft bearing. And make sure that none of the ball bearings have come out of the upper bearing as well.
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Mar 22, 2019 09:39 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
