how do you remove the guage cluster?
Old Mar 27, 2005 | 11:57 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i am swaping in my 145mph speedo today, and can't seem to get the cluster portion out of the dash. you know, the white piece that all of the guages sit it, how the heck do you remove it?
Old Mar 27, 2005 | 12:03 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
there are two 10mm nuts in the recesses for the dummy lights, one on each side at the bottom. also you have to disconnect the speedo cable from the back of the speedo before the cluster will come out completely.
Old Mar 27, 2005 | 01:19 PM
Abubaca's Avatar
The speedo cable is held on by a clip behind the cluster. I get a long flathead screwdriver and contort myself so that I'm lying on the floor looking UP at the steering column. A little flashlight will help too. Once you find the clip and the cable
, you'll see how to remove it with the screr driver. You kinda have to compress the side of the clip. It's hard to explain, but when you see it you'll know.
Old Mar 27, 2005 | 01:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Do yourself a favor too and lower the steering column an inch to give you more room to get the cluster out. There are two bolts holding the column up, you don't have to remove them completely, just loosen them off.
Old Mar 27, 2005 | 01:54 PM
mw66nova's Avatar
Engine: 7.0L
thanks guys! i lowered the column and made it a bunch easier. i got it all swapped out, and boy, am i happy! tht stock 85mph speedo looks so outta place in these cars. the 145mph looks sweet. kinda different next to one of the big fuel guages, instead of the tachometer, but, hey, it's "unique"! now, i just gotta get the drive gears swapped in the tranny so my speedo reads accurately. with the 4.10's and 28" tall tire, it's all kinds of messed up! at 70mph, it reads 90!
Old Mar 27, 2005 | 03:39 PM
Stevo's Avatar
Car: Pair of 92 Z28s
i guess the older camaros used cables? as opposed to 91-92?
Old Mar 27, 2005 | 03:50 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
tru
Old Mar 27, 2005 | 09:38 PM
mw66nova's Avatar
Engine: 7.0L
all camaros 82-89 got a mechanical speedo. i know that some 'birds got them earlier, not sure when. i'll have to get a picture of the way the cluster looks now, it's kinda cool with the base model cluster.
Old Mar 28, 2005 | 12:46 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Firebirds got them in 86.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TrevinE
Sep 14, 2015 03:20 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
90formulaVortec
Sep 8, 2015 12:42 AM
andy74
Sep 3, 2015 08:41 AM
