Hood doesn't "pop" open.....what needs adjusting?
Old Jun 19, 2005 | 07:43 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Okay the hood is supposed to pop up so you can slide your fingers in and unlatch the clip and raise the hood....well w/i the last 2 weeks the popping has stopped and I have to rapidly press on the hood for it to wiggle free and finally push up.
What do I need to adjust? The cable?
Any ideas?
Old Jun 19, 2005 | 08:06 PM
Rage13's Avatar
Car: 89 Firebird
losen the 2 bolts that hold the latching bar on the hood, just enough so they still hold the bar in place but so you can move it with your fingers. now push the hood down a few times so the bar hits the latch but not enough to catch. tighten bolts and smile while you no longer have to do a drum solo on you hood
Old Jun 19, 2005 | 08:23 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
I have to do that everytime. A simple tap on the hood brings it up Yeah pretty sad when you have hood pins and the stock hood latch
Old Jun 19, 2005 | 08:32 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Keep the hood latch well-greased. My hood used to do that also. Hit it with some PB Blaster first to clean it. Wipe off excess and then apply some multi-purpose grease to the latch. I use the silicone grease that I use for greasing the front end. Open and close the hood a few times to work the grease in. I haven't had problems since.
Also you may need to replace the hood spring. They do wear.
Old Jun 19, 2005 | 08:57 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
I agree.. On two thirdgens with the same problem, greasing that latch up really good seemed to work wonders.
Drum solo ... Yeah I remember having to do that. Good way to describe it.
Old Jun 19, 2005 | 10:26 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
yup, It happened to me too. grease the latch it will be fine.
Old Jun 19, 2005 | 11:28 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
not just thirdgens
GM vehicles
cousins 91 S-10 did it
my 86 suburban does it
my 92 camaro does it
buddies 85 grand prix does it
the list goes on, lol
Old Jun 20, 2005 | 04:11 PM
deadboyz's Avatar
Car: 1985 Trans AM
Transmission: AUTO.
worked!!!
for the longest time I had to play drums on my hood also, and I finally fixed it, thanks for the help guys, I'll lubricate it as soon as I go to home depot. I should have asked this question a long time ago...
Old Jun 20, 2005 | 07:03 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
You might also want to try and adjust the latching mechanism itself.It may have fallen/moved downward over time after so many hood closings.
Old Jun 20, 2005 | 07:18 PM
Car: 92 RS
Engine: a slow one
I found it was almost always a stretched cable.
add a couple bb shot fishing wieghts in there for a temp fix, then lube it all up good to slow down further wear on the cable.
Old Jun 20, 2005 | 07:47 PM
Rage13's Avatar
Car: 89 Firebird
the cable can stretch all it wants, it makes no difference on opening. only thing that holds the handle back from sliding right out is the cable itself. ask me how i know...
Old Jun 20, 2005 | 10:25 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
rotfl... I know of this first hand, my grand ams hood latch jus had no feel when i went to open it one day, and i could pull back on the release all i wanted with no effect, and without thinking i just pulled and pulled the little metal wire until i got it all out, before actually realizing that some pliars and maybe a spot weld would have remedied the situation now i have an ultra custom zip tie manual hood release
Old Jun 20, 2005 | 10:29 PM
...smile while you no longer have to do a drum solo on you hood
haha thats the funniest way of describing that, and for years me n my old man have been doing that until one day i took the liberty of grabbing a can of pb rust bust and some grease, and no longer imitate Alex VanHalen when i have to open the hood
Old Jun 21, 2005 | 08:26 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
I dont have to do a solo. I've got it down to where i just hit it once in the right spot and it pops.
awhile back when i had some work done on the car the mechanic simply put grease on it and it worked for about 6 months till it wore off....
explain this "adjusting the hook latch" deal in more detail please.
Old Jun 21, 2005 | 11:22 AM
Justin Horne's Avatar
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
I always wonder about our Yukon's pull release.. The thing has as next to zero pull weight as you can get, but whatever works, I guess...
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
deracer
Apr 11, 2016 12:04 AM
86IROC112
Aug 21, 2015 07:20 PM
