Repairing strut tower rust
Old Jun 19, 2005 | 09:42 PM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
So I have the same problem that many third gen owners have with the driver side strut tower rusting out from the wheel well in. I searched the forums and I couldn't find any post with some pics of the repair process, so I thought I would document mine. There's nothing like taking a cutting wheel and welder to your car!
So here was the problem after I took out the strut and upper strut mount and got rid of most of the bad rust so I could see what I was dealing with.
Old Jun 19, 2005 | 09:50 PM
mgilorma's Avatar
Car: 90 RS
woops messed up there, look down for pics
Old Jun 19, 2005 | 09:54 PM
mgilorma's Avatar
Car: 90 RS
side closest to the firewall
Old Jun 19, 2005 | 09:57 PM
mgilorma's Avatar
Car: 90 RS
closest to the front
Old Jun 19, 2005 | 09:58 PM
mgilorma's Avatar
Car: 90 RS
inside the wheel well
Old Jun 19, 2005 | 10:04 PM
mgilorma's Avatar
Car: 90 RS
another from the wheel well, you can see the line where i want to cut
Old Jun 19, 2005 | 10:05 PM
mgilorma's Avatar
Car: 90 RS
Old Jun 19, 2005 | 10:08 PM
mgilorma's Avatar
Car: 90 RS
before i started cutting, I welded two pieces to support the strut tower because I was removing all the support from the wheel well, and the only thing that is holding it up is the part where it is welded to the fender frame. This pic is after the fact but just showing where it was from when i was trying to get all the bad metal out.
Old Jun 19, 2005 | 10:09 PM
mgilorma's Avatar
Car: 90 RS
this is the one from inside the engine bay
Old Jun 19, 2005 | 10:10 PM
mgilorma's Avatar
Car: 90 RS
another pic of that support
Old Jun 19, 2005 | 10:12 PM
mgilorma's Avatar
Car: 90 RS
the following pictures are after all the cutting and preping for primer and paint.
Old Jun 19, 2005 | 10:13 PM
mgilorma's Avatar
Car: 90 RS
inside wheel well, firewall side
Old Jun 19, 2005 | 10:19 PM
mgilorma's Avatar
Car: 90 RS
this is the front side
Old Jun 19, 2005 | 10:20 PM
mgilorma's Avatar
Car: 90 RS
from the top, firewall side
Old Jun 19, 2005 | 10:22 PM
mgilorma's Avatar
Car: 90 RS
from top, front side
Old Jun 19, 2005 | 10:23 PM
mgilorma's Avatar
Car: 90 RS
here is all thats left
Old Jun 19, 2005 | 10:25 PM
mgilorma's Avatar
Car: 90 RS
So I have a coat of primer on the underside of the strut tower, I think I'm going to get some POR-15 that everybody is raving about and use that. I have a sheet of 16 gauge steel that I am going to be repairing the wheel well with, I'll post new pics as they come.
Old Jun 19, 2005 | 10:34 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Nice pics and details but I think there is a 3 picture limit.
Old Jun 19, 2005 | 11:25 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
too bad about the 3 picture limit
posts like this are great and should be part of a site database
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
think posts w/ technical information which will help the thirdgen community as a whole can be omitted from the three picture limit. Whether a mod thinks that or not is a different story. I'd say a 3 pic limit of showing shots of your car, or your new interior, or hood, etc. A good repair, or modification where the pix will help those who follow, bring the pictures on.
Old Jun 21, 2005 | 09:55 PM
Cra-Z-Canuck's Avatar
Car: 88 IROC Convertible
Engine: 355 (Finally!)
Transmission: Auto :(
Absolutely....that's what we're here for. As long as it's not 15 pics of someone's new rims from 15 slightly different angles. Pics of a build up or any procedure help to tell a story - a pic is worth a thousand words.
Kudos to mgilorma for documenting that.
Old Jun 22, 2005 | 07:30 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I can honestly say that I've never seen strut tower rust anywhere near that bad, and considering that I'm from the North East, that's saying a lot.
My 86 Camaro pretty much had no body left, and the floor pans weren't much better, but even that didn't have so much as a pin hole through the strut towers. It just boggles me that you got such severe rust in that area.
In any case, it looks like you're making great strides to get it repaired. If it was me, I think I would have replaced the whole panel instead of piecing it in, but as long as you weld it properly, that repair should be just as strong as stock.
Old Jun 22, 2005 | 09:06 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
My first thought was the car had been wrecked and this area heated and reshaped, but doubt it could or would have happened like this. I'd guess a bad piece of steel from the mill. Looks like a tricky repair, hope it turns out good.
Old Jun 22, 2005 | 09:17 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
It's actually fairly common with all the sandwiched sheetmetal and pinch welds. I noticed a little cancer in this area when I had my struts out recently. I just took a wire wheel to it and hit with with some RustTuff Auto Zone crap paint. I know I have to get in there again and do it right, eventually.
Old Jun 24, 2005 | 12:11 PM
mgilorma's Avatar
Car: 90 RS
as far as I'm aware, no one makes replacement wheel wells for our thirdgens. The only options I had were to piece it in or try to cut apart a donor car and then weld that back in to mine. The biggest chalenge for me right now is not really having any metal working tools. I'm not going to be able to start working on it again until next week, but I'll try to keep up with the documentation.
Old Jul 2, 2005 | 06:39 PM
mgilorma's Avatar
Car: 90 RS
time for new pics, been kind of busy with work, putting in a couple of hours a night hear and there. This first pic is of the first piece that i cut out and hammered and bent into shape, then cut out a hole for the strut and holes for the alignment and strut tower brace.
Old Jul 2, 2005 | 06:41 PM
mgilorma's Avatar
Car: 90 RS
here it is, all it needed from this point is i small piece on the back part, and two large pieces on each side.
Old Jul 2, 2005 | 06:42 PM
mgilorma's Avatar
Car: 90 RS
jump ahead a whole lot of welding, hammering and bending, this is the piece out of the car, primed and ready for por 15.
Old Jul 2, 2005 | 06:46 PM
mgilorma's Avatar
Car: 90 RS
so to end today off, i painted the underside of the strut tower and the top side of the "new" wheel well with por-15. Tommorow I'll be welding that piece in, painting everything, and that should be it.
Old Jul 3, 2005 | 03:39 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
I had rust that bad on my Pass side, once i got it cut out, welded in a new metal, smoothed it with bondo, and i got the idea of smoothing out the edges around the mount, so now that the engine is finnaly out of my car, im going through the bay, striping it, and smothing it out with metal/bondo/epoxies before the new engine goes in
Old Apr 7, 2015 | 06:09 PM
lowkeyCamaro's Avatar
Re: Repairing strut tower rust
I'm having the same problem with my strut towers, my girl aunt just game me her 87 camaro for free! Lucky me huh lol...but anyways do I have to take the engine out in order to do the strut towers on the frame?? Please lmk I will send pics asap...
Old Apr 10, 2015 | 02:08 PM
mgilorma's Avatar
Car: 90 RS
You shouldn't have to take out the engine to do the repairs. I'm going to update some of the pictures on this thread so you can get a better look at what my repair looked like. Have fun!
Old Apr 10, 2015 | 02:47 PM
mgilorma's Avatar
Car: 90 RS
So ten years later I'm going to finally finish up this thread....
I clamped the patch piece to the strut tower and started welding...
Old Apr 10, 2015 | 02:51 PM
mgilorma's Avatar
Car: 90 RS
After grinding, I applied POR Patch to all the seams to make sure my less than optimal welds would be protected...
Old Apr 10, 2015 | 02:52 PM
mgilorma's Avatar
Car: 90 RS
And finally a finish coat of POR-15, ten years later it's still in perfect shape
Old Apr 12, 2015 | 09:33 PM
phasevariance's Avatar
Car: 1992 Camaro RS & 2014 Camaro SS V8
Engine: 305 & 6.2L
I remember seeing another thread. A dude had cut it out and welded in from a donor car.
Old Apr 13, 2015 | 11:36 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Wow, good for you on saving the car and doing it right, the repair looks great. A lot of people, myself included, would not touch a car with strut towers that bad. I'd rather be fixing floors or quarters
Old Apr 13, 2015 | 11:59 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
10 years later, still have it, and still posting!!!!
Old Apr 14, 2015 | 08:24 AM
mgilorma's Avatar
Car: 90 RS
Thanks guys. Bought the car from a friend after I graduated high school in 97. Obviously a lot has changed in life since then, married, kids, etc... I will NEVER let this car go, my kids will have to figure out what to do with it after I'm gone.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
FueledSoul
Sep 30, 2015 09:18 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
tcflint
Sep 27, 2015 05:58 PM
ironbmt
Sep 27, 2015 06:00 AM
