visibility with tachometer
Old Jun 22, 2005 | 07:09 PM
89TPI350's Avatar
Car: 1989 Formula 350
Transmission: 700-R4
I recently purchased a 10,000 Rpm tachometer from auto meter for the inside of my car. I wanted to install it to the right of the wheel right over the radio. I noticed that while putting it in place it blocks a bad spot where visbililty is needed because im a shorter guy. I tried other spots, and There is no other place to put this that would look good, and im wondering if it was a bad idea to purchase it. does anybody have an aftermarket tachometer in a 1989 firebird and can you tell me where you put it where it didnt block to much visibility. thanks alot for the help
Randy
Old Jun 22, 2005 | 07:31 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
i know on cars where i've mounted a tach, i've normally attached it to the steering column. YOu could even put it on the column so that it's over the factory tach, another option would be to hang it from under the dash instead of infront, however, w/ the firebirds air vents location, that might not be that feasable, can't remember since i don't have the old dash in anymore.
Old Jun 22, 2005 | 09:03 PM
gilley's86's Avatar
Car: 1986 Camaro SC
Engine: 305, AKA 30WHY
Have you considered installing it to the left of the wheel in the corner between the A pillar and the dash. I've seen a lot of people do that. My brother kind of has the same problem with his tach on the dash in his 69. Just a thought.
Gilley's86
Old Jun 23, 2005 | 01:51 AM
EvilCartman's Avatar
Car: '82 Z28
Here's where mine is, didn't want to drill into the dashpad.
Old Jun 23, 2005 | 11:32 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
step #1, bring it back
step #2, buy a tach that matches your engines capabilities
step #3, try to put it in the stock location
otherwise there is no good spot on a bird, your going to block something wherever you put it
Old Jun 23, 2005 | 11:38 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Big tachs on the dash are stuiped, looks cheap, unoriginal, and uncreative.
Esp. when the stock tach is still in the dash.
Old Jun 24, 2005 | 06:19 AM
Car: '82 Z28
Sorry if I need a more accurate tach that is close to my line of sight. I've taken the stock tach to 7,000 (which is as high as it goes) but who knows if the engine was actually turning that rpm. I'll trust my aftermarket tach over a factory unit any day, especially when turning those RPM's. It's seen 7,300 rpm so far and will probably see around 7,800 rpm at the track if I used the nitrous.
Old Jun 24, 2005 | 08:14 AM
Car: 1971 Camaro
Engine: 427
How about just a shift light,. and a rev limiter?
Old Jun 24, 2005 | 08:55 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I agree, but sometimes you just need an aftermarket one and don't have the skill to install it where the stock tach was. On a bird there isn't much room without massacring the circuit board that the guages are attached to.
Old Jun 24, 2005 | 09:05 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you need to do a solution similar to this:
https://www.thirdgen.org/techbb2/att...postid=2125068
Old Jun 24, 2005 | 09:09 AM
Car: 1971 Camaro
Engine: 427
MrDude_1,
Old Jun 24, 2005 | 12:06 PM
badazta87's Avatar
Car: 87 GTA
Engine: Under Construction
Axle/Gears: 3.70:1
I'm having the same problem. I have a digital dash and there is no way im gonna hack up the board just to install an aftermarket tach. I guess Johnny Blaze is right, just have to settle for a shift light and rev limiter.
toones
Jan 6, 2016 06:00 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
mdtoren
Aug 23, 2015 12:52 PM
ChevyZ71
Aug 13, 2015 07:30 AM
