How hard is this going to be to fix?
Old Jun 23, 2005 | 08:48 AM
turbodave's Avatar
Car: 84 Z28, L69
Engine: 5.0 HO
As you can see, there's a lot rust/rot in the center area under the seals on my T-Tops.
(I'm hoping my pictures will post)
I know I'll need a new set of seals, but how hard is the rest of it going to be to fix???
This is on my 84 Z28 L69 (orig owner).
Old Jun 23, 2005 | 08:53 AM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
It all depends if its just surface rust. If it is surface rust, you can just grind it down and seal it, then possibly paint if you wanted to. If its rusted all the way through, then youre gonna have to take all of it out or just that section. I dont have T-tops so i dont really know what you would have to replace.
Take a dremel and grind some of the rust and see if you can find solid metal underneath it.
Old Jun 23, 2005 | 09:24 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Replace that bar. They are cheap at a junkyard and its not too hard of an install. Just use lots of sealant.
Old Jun 23, 2005 | 11:14 AM
turbodave's Avatar
Car: 84 Z28, L69
Engine: 5.0 HO
Ya, it's pretty much rusted through that bar.
Old Jun 23, 2005 | 11:45 AM
CaysE's Avatar
Replace that t-bar: http://www.hawksthirdgenparts.com/in...?v=1&pid=21280
With the condition that it's in, you will not be able to apply sealant and install the weatherstripping properly. You will have to clean up the metal underneath and apply sealant along the edges and in the screw holes before installing the new bar.
Old Jun 26, 2005 | 06:35 PM
BonesNIS's Avatar
Car: 1987 Camaro Iroc Z
Just replace the entire section. I did way back. I believe there are only four screws and a whole bunch of cement holding it down. I got my from the dealership. Can't remember how much, but I know it wasn't expensive. Once you replace it, just make sure you wipe it down completely after the rain or a wash.
Old Jun 26, 2005 | 07:00 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
get a new gm bar
Old Jun 27, 2005 | 06:12 AM
turbodave's Avatar
Car: 84 Z28, L69
Engine: 5.0 HO
Originally posted by crazy3rdgen
get a new gm bar
Great, that's the piece I will likely need. Are they still available from GM (dealerships), or what's a good source?
Thanks!!!
Old Jun 27, 2005 | 10:19 AM
Car: 2002 SS
Engine: Ls1
Well, my dad works at a chevy dealership and I was like, I need this part. When i received the bar it was wrapped in a bag that had Gm all over it sealed air tight so gm should still have it.. This was only labout 3 weeks ago.
Old Jun 27, 2005 | 11:04 AM
turbodave's Avatar
Car: 84 Z28, L69
Engine: 5.0 HO
I don't suppose you have the part number handy do you?
Ooops, sorry, just saw CaysE's post
Old Jun 27, 2005 | 03:41 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
now it looks like a fairly easy piece to install, is it so?
Old Jun 27, 2005 | 07:57 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
what kind of sealent would you use? I thinking of replacing mine
Old Jun 27, 2005 | 08:25 PM
JB22's Avatar
Mine is getting pretty swag too, will be replacing that and all stripping when I get her painted.
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
dbrochard
Oct 3, 2015 12:43 PM
Fronzizzle
Sep 8, 2015 12:10 PM
apie2546
Sep 5, 2015 07:40 PM
