Hit a ditch and flooded
Old Jul 24, 2005 | 12:29 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
Old Jul 24, 2005 | 01:37 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
Wow, sounds like you got lucky.
I usually get scared when my car is at operating temp and I hit a puddle (not deep) and water splashes and hits the exhaust and smoke starts coming out from under the car.
Now to actually be that far underwater, that would be quite crappy.
Old Jul 24, 2005 | 02:06 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
sounds very lucky, guess you'll go even slower over puddles in the future. Ya definately got lucky though, had that engine gone under, you'd be speaking a different tune, good luck getting everything cleaned up.
Old Jul 24, 2005 | 03:07 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
My neighbor who drives a wrecker, said he pulled a guy out of the ditch of the same movie theater that we had to leave earlier. But the whole front of his car went underwater. And when he pulled it out he asked the guy what he wanted to do and the guy said he was gonna drive it. My neighbor told him that he didnt think that would be a good idea because of water in the motor. The guy insisted tho and cranked it up. It ran for a about a minute before the whole thing locked up. Not too smart.
Old Jul 24, 2005 | 07:35 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
yea. that guy was not to bright.. he sohuld have had it towed home, drained all the fluids, let everything dry out, and then put new fluids and filters in... that helps alot. been there and done that.. But then, Mine is oldschool, no computers..
Old Jul 25, 2005 | 05:09 PM
sasser43's Avatar
Car: 89 GTA
Engine: 350 TPI L98
yea i would have changed the oil. ran it for a short while then change the oil again. that way it would get all the water out of the bearings and stuff.
Old Jul 25, 2005 | 06:55 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
well there shouldn't be water inside the crankcase.. it should only get inside the combustion chambers, unless your valve covers are open for some reason..
But yeah you got lucky, glad you and your ride are okay!
Old Jul 26, 2005 | 06:41 AM
85f-bird's Avatar
Engine: 2.8L, LS1
well, water in the combustion chambers sounds bad enough to me. Because of the in-compressability of a liquid, i'd be expecting to find bent connecting rods as the water enters the compression stroke. and i'd have a feeling that the water will rust up those beautifully clean and slick cylinder walls in a couple seconds....
Old Jul 26, 2005 | 10:30 AM
not to say anything.. but in a thirdgen i doubt that all the gaskets and everything on the Pan and timing cover could keep any water out of the oil pan.. especially if it is the stock engine in the car, or a never rebuilt engine out of another one.. gaskets get pretty crappy after 10 years. especially when they have to expand or shrink very quickly.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
RS Reaper
Sep 27, 2015 07:04 PM
Twinn Engines
Sep 25, 2015 06:27 AM
