Hood/Bumper cover gap
Old 09-09-2005, 12:24 AM
black_highway's Avatar
Car: 91' RS Camaro
Engine: 305c.d. Toilet Bowl Injection
This has been bugging me since i got it back from the shop, that stupid gap just won't go away! it has a new headlamp support, a new cover (all GM) and a new absorber, and that didin't do anything, it still has it! it had it with the old peices to, so i am just wondering if anyone else here has had that problem and if they have fixed it sucessfully?
here is a pic.
sorry they are so dark, but the gap is more pronouced than it looks.
Old 09-09-2005, 02:53 AM
Xophertony's Avatar
Car: 1988 Trans-Am GTA
Engine: 5.7L TPI
Transmission: WC-T5
Axle/Gears: BW 3.27
somthing during the day might help, i can't see jack in that photo.
Old 09-09-2005, 02:58 AM
Xophertony's Avatar
Engine: 5.7L TPI
Transmission: WC-T5
Axle/Gears: BW 3.27
i tinkered with it
Attached Thumbnails Hood/Bumper cover gap-gap2.jpg
Old 09-09-2005, 02:59 AM
Xophertony's Avatar
Engine: 5.7L TPI
Transmission: WC-T5
Axle/Gears: BW 3.27
there should be a couple of rubber screw things on the sill where the hood rests in the front, if you screw them in a little further the hood may sit lower.
Old 09-09-2005, 08:34 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I agree, just lower the rubber stoppers.
Old 09-09-2005, 09:24 AM
Car: 91' RS Camaro
the hood aligns with the fender lines perfectly, it's the bumper cover that is not correctly aligned, has anyone else fixed that?
Old 09-09-2005, 09:32 AM
Car: 86 T/A
Engine: HSR 355
Shim it. Put washers underneath the upper bolts on the bumper cover.
Old 09-09-2005, 09:38 AM
Car: 91' RS Camaro
those onces on the front, correct? because i want to run those plexiglass covers, and with the way the nose is fitting, they would look BAD.
Old 09-09-2005, 09:40 AM
Car: 86 T/A
Engine: HSR 355
Yeah, thats right. What plexiglass covers? You can probably remove the bumper and bend the sheet metal up if you have to, but shimming is easier.
Old 09-09-2005, 09:42 AM
Car: 91' RS Camaro
what type of shims did you use?
Old 09-10-2005, 08:50 AM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
try moving the hood latch down. my car had a hidious gap unti l i moved the latch. looks as good as new now.
matt
Old 09-10-2005, 10:01 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
There are bolts(2 per) on the sides of the headlamp support(next to inner lamp).Loosen those & the center nuts, behind the center bumper emblem.Lift up on the bumper & tighten the nut/bolts.Check gap,repeat if required.The hood latch as mentioned above is also helpful.There are no shims required or used(except on the steel bumper to frame horns,which does nothing for the bumper cover in terms of raising it.
1Aauto
Sponsored Vendors
10-05-2015 03:14 PM
1Aauto
Sponsored Vendors
10-05-2015 03:13 PM
roysatikas
09-22-2015 08:15 PM
codeysabatini
09-20-2015 11:36 AM
355tpipickup
09-13-2015 11:35 PM
Quick Reply: Hood/Bumper cover gap
