5 point harness in a non roll cage
Old Oct 3, 2005 | 06:58 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Has anyone installed 5 point harness in 3rd gen without using a roll cage?
If so please enlighten.
thx
Jeff
Old Oct 3, 2005 | 09:23 PM
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
y? it wouldn't be legal to race where the harnes is mandated
Old Oct 4, 2005 | 07:13 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
not only that, but it would be downright dangerous. If you just mount the shoulder harness to the floor behind the seat, when you get into an accident, it'll pull your shoulders down and compress your spine. If you're lucky it'll kill you, but if not, you better hope that somebody builds a car that you can control through a straw.
Old Oct 4, 2005 | 06:22 PM
jjlabinski's Avatar
Engine: shinny 350
car is mostly for show. I know the required mounting locations and angles but am wondering if maybe someone fabbed a single tubular structure that would mount to the under carriage in some manner.
Old Oct 4, 2005 | 07:02 PM
montesa311's Avatar
you cuold put in a 4-6 pt roll cage, that would make it safe and personaly i like the look of a cage in a car
Old Oct 4, 2005 | 08:18 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Old Oct 4, 2005 | 11:20 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
that was well put
Old Oct 5, 2005 | 04:07 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
I agree that it should not be mounted to the floor. I have built a harness bar that connects to the rear seatbelt mounts. This takes care of the problem of the angle, but if you roll the car you will still have a problem. I will be installing a 6 point bar next spring so that I can be safe on the road courses.
Old Oct 5, 2005 | 04:17 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I installed one...but as stated above...it would be dangerous to use it...so..I just installed it for looks only.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
middian
Sep 5, 2015 01:42 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
SlowAZ28
Sep 2, 2015 05:19 AM
