center console
Old Nov 13, 2005 | 11:58 AM
Hunteradam2001's Avatar
Car: 86 Trans Am
center console
I have a 86 trans Am, automatic, and would like to buy a black center console. Mine is tearing away from the shifter area and the back cover is coming off. Any idea where the best place to get his unit would be? Thanks
Old Nov 14, 2005 | 06:47 PM
tagta189's Avatar
I'm not sure if they ever made black consoles.Only grey.If you ever see a black one that's because somebody painted or dyed it.Not sure about the 4th gen consoles though,maybe they had black ones.That might be a good solution if they did.Anybody out there know???
Old Nov 14, 2005 | 07:01 PM
Car: 86 Trans Am
From what i have read, it is a pain in the A** to install the fourth generation consoles n a thrid generation car. As much as i would love to do it and as much as i love the way it looks, I maybe just a little to impatient to do the work?
Old Nov 14, 2005 | 07:17 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Do a search here for a ton of info on the 4th gen console swap...apparently using a 6 speed console is fairly simple, using an auto is a challenge.
And yes, some 4th gen consoles could be had in black (ebony)
For the original question, there is a brand new GM 3rd gen console on Ebay right now. Expensive, though.
Old Nov 14, 2005 | 07:22 PM
Car: 86 Trans Am
Ill look, thanks for the heads up. Ya, mines a automatic, LOL
Old Nov 14, 2005 | 07:29 PM
Bull's Avatar
Engine: LT1; None
Even if your thirdgen is an automatic, you can use a 4th gen manual console and it will work fine
Old Nov 14, 2005 | 07:36 PM
Car: 86 Trans Am
Good to go. Again thanks for the heads up. Your knowledge on this type of thing far exceeds mine. I really do appreciate the help.
Old Nov 14, 2005 | 07:41 PM
Bull's Avatar
Engine: LT1; None
My knowledge is pretty basic...I just read a bunch of stuff after doing a search. I plan to try and do the swap myself in the next month or so.
Old Nov 14, 2005 | 07:42 PM
Car: 86 Trans Am
Do me a favor and keep me posted on how it turns out.
Old Nov 14, 2005 | 07:43 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
The 4th gen console install is VERY easy. Mine bolted right up in the console storage box, and I just had to figure out how to fasten the front of it to the car. Then again, I'm also using the 4th gen dash and had the entire interior out when I did this..
Old Nov 14, 2005 | 07:52 PM
Bull's Avatar
Engine: LT1; None
What did you end up fastening the front to?
Hunteradam, I will definitely keep you posted
Old Nov 14, 2005 | 07:56 PM
Car: 86 Trans Am
astoria18:
Yes please tell us. And where did you obtain your console?
Bull:
Thanks brother.
Old Nov 17, 2005 | 04:07 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
The Firebird radio pod attaches at the back to a bolt on the top of the transmission tunnel. Obviously I had no need for the radio pod, so I just fabbed a simple L shaped bracket that went from that bolt to the hole in the back of the compartment where you can store tapes on the 93-97 console (I think that's what those slots are for. What was GM thinking?). I'm not sure how easy that explanation is to picture, but the console doesn't move around at all.
Old Nov 17, 2005 | 04:15 PM
Bull's Avatar
Engine: LT1; None
I'll admit it...I am confused. Why didn't you need the radio pod? A 4th gen console doesn't eliminate the pod, so I don't quite get it. Also, isn't where the pod located, and where the CD storage located pretty far apart? The pod would be at the front of the console, and on the '97-02 consoles at least I know the CD slots are in the console storage area at the back.
Old Nov 18, 2005 | 08:33 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
astoria18:
Bull:
Thanks brother.
You can find a lot of consoles on ebay. I have seen a bunch of 4th gens in the wrecking yards.
Old Nov 18, 2005 | 11:15 AM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
The 93-96 Camaro console has a pod built on to it near the front that stores tapes. However, you can remove the pod pretty easily if you want to keep your thirdgen dash and radio pod.
Old Nov 18, 2005 | 11:31 AM
Bull's Avatar
Engine: LT1; None
Oh, ok, I get it now. Didn't realize that about the earlier consoles, and also didn't realize you swapped over to a 4th gen dash as well. That must be a lot of work!
Old Nov 18, 2005 | 03:10 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
It wasn't too bad, took maybe a weekend to finish. Obviously that picture isn't the finished product, and I'm still working on the door panels. I love the updated look.
Old Nov 18, 2005 | 06:01 PM
Car: 86 Trans Am
I like those seats. Where did you get them and how much did they cost you? On top of that, how hard where they to install.
Great looking console, and thanks for clarification on the project.
Ed1LE
Sep 30, 2018 09:14 AM
Lbibb
May 5, 2016 12:00 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
ndndndnd
Sep 28, 2015 08:00 AM
