t top sun visor problem help!
Old Jan 21, 2006 | 09:00 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Hello
I have a t top conversion done to my iroc and it still has the hartop sun visors. They flap down when im driving and it drives me nuts.
How do i make them slow or hard to move so they stay up? Also is there a difference between hartop and t top visors?
Speed
Old Jan 22, 2006 | 08:44 AM
Car: 1989 IROC-Z
Engine: 346 LS6
Is there no solution to this?????
Please help me out
Speed
Old Jan 22, 2006 | 09:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Hey, Speed,
There is a difference between the two. The coupe version is wider. Often what happens is that the rod which is inserted into the visor has broken loose from its housing/hanger, and as a consequence, rotates when it's designed to be stationary. As a result, flop will occur regardless of how much the visor is tightened to the rod. New hangers and you're ready to go. I bought mine at a bone yard for next to nothing.
JamesC
Old Jan 22, 2006 | 02:51 PM
C. W. H.'s Avatar
Car: 1989 Firebird Formula 350
Transmission: 700
I purchased the plastic inserts from the local Chevy/Pontiac Dealer. They cost around $1.00 per visor. All you have to do is remove the one screw that holds the visor shaft to the visor, slide the visor off, remove the damaged plastic insert, replace with new one, and reinstall the visor and the screw.
I did waste alot of time in the salvage yards looking around and then I decided to call the parts counter at the delearship...wow, they order it and it came in the next day. I ordered 6 of them for future visor problems..plus incase they get discontinued.
Later,
Old Jan 22, 2006 | 03:38 PM
JamesC's Avatar
I've never heard of the insert's being a problem, but I can see how it might be. If it's the rod, however, the insert won't help.
JamesC
Old Jan 30, 2006 | 06:37 PM
Car: 1989 IROC-Z
Engine: 346 LS6
I took my visors off today. The driver side has a broken plastic insert but the passenger one is mint. Yet they both flop equally. Im not sure what to do next to fix the problem... Do i need new arms?
Speed
Old Jan 31, 2006 | 11:08 AM
JamesC's Avatar
Take the visor off the rod. Try jiggling and/or twisting the rod with your fingers. If the rod rotates/moves, you've found your problem.
JamesC
Old Jan 31, 2006 | 12:21 PM
Car: 1989 IROC-Z
Engine: 346 LS6
That must be it. Because i can move them a little bit and thats probably what is doing it. Ca the arms be fixed or do i order new GM ones?
Thanks you have been a big help
Speedmachine
Old Jan 31, 2006 | 12:29 PM
JamesC's Avatar
You might be able to use some BD weld to fix the rod in place. I simply hit the bone yard until I found a couple that were unbroken. They work and look like new for a few dollars.
JamesC
Old Jan 31, 2006 | 02:12 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
There is a screw on the visor itself, I just tightened it and it kept my visors from slowly falling down. I had hardtop visors on my t-top for a while, worked fine. I ended up shaving off the visors entirely since I never use them.
Old Jan 31, 2006 | 06:42 PM
Car: 1989 IROC-Z
Engine: 346 LS6
Well i would like to get rid of my visors because they are aged and ugly...But i cant because im not about to buy another head liner....I have a C&C car and it has the hartop headliner just cut like a t top and then glued like crazy. Besause of that i dont want to risk anythingby trying to do up another headliner.
Is there a method for re furbashing visors and tightening up the material?
Thanks guys
Speed
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Poncho92
Aug 7, 2015 08:15 PM
