no hatch keys
Old Feb 12, 2006 | 07:59 PM
1bad88droptop's Avatar
Car: 88 camaro drop top custom
Engine: turbod lt1
Transmission: t56
no hatch keys
ok im prolly gettin this z28 that was towed to my dads work and since it was towed theres no keys to it. So what would be the easiest way to get the hatch open so i can change out the locks?
Old Feb 12, 2006 | 08:12 PM
87TAairlineyard's Avatar
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
This may be a way around this problem- if you request a car report from Pontiac Historic Services (sorry don't know the name of the Chevy equivalent), one of the sheets they will include is the original invoice which has the key numbers in the upper left hand corner. You can take those key numbers to your dealer who can then get the right keys. The report I got for my TA cost $35- it might be worth it to save you the trouble of having to get new lock cylinders for the hatch and doors.
Old Feb 12, 2006 | 08:21 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
If it has the hatch release button on the console try that first(if you haven't already.You could fold the back set down and remove the trim panels and pop the latch from the inside.
Old Feb 12, 2006 | 08:22 PM
Engine: turbod lt1
Transmission: t56
ok sounds good but where would i find the place i need to get them from, like how could find the place for chevy?
Old Feb 12, 2006 | 08:25 PM
Engine: turbod lt1
Transmission: t56
how do i pop it from the inside?
Old Feb 12, 2006 | 08:28 PM
Engine: turbod lt1
Transmission: t56
Old Feb 12, 2006 | 09:17 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Mine quits every now and again and I can't pop it electronically (intermittent ground on park brake). I remove the cargo light assembly (lens and all), behind the light the mechanism has a slot that a long flat screwdriver can fit into. Give that a turn and should pop the hatch.
Old Feb 13, 2006 | 11:50 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
A locksmith should be able to make a key for you.
When I bought my 88 formula, it was a repoed car and only had the ignition key, but it had t-tops and the remote hatch button.
the locksmith said he could make a key from the t-tops or from the rear hatch compartment, we chose the rear compartment since it was easier to remove than the t-top lock.
Cost me $25 + $2 for each key he made.
Old Feb 14, 2006 | 01:27 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
This has been posted before, Remove the hatch light. Remove the 10mm screw holding either the hatch release solenoid or manual latch release to the pull-down motor. You'll see a square-shaped hole. Use your finger or a screwdriver to rotate the tab you see to release the latch.
Lon
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Linson
Oct 1, 2015 09:50 PM
formula00ra
Sep 28, 2015 11:50 AM
