How to prevent dashboards from cracking.
Tell me, this seems like a common thirdgen tragedy.... I think t-top shades would help with t-top cars. So would a carpet dash cover. I have leftover carpet and can make both of those. And a windshield heat deflector, maybe? What else can be done?
Search engines work wonders.
http://www.303products.com/main.php?infopage=protectant
http://www.303products.com/main.php?infopage=protectant Senior Member
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
I hit my knee on my dashpad getting into the car on a 0 degree day and cracked the corner. I'm just gonna give it a coat or 2 of resin and paint the whole thing to match the color of my car
Car: 1987 Camaro IROC-Z
Engine: LB9
mines had about zero special care over the years, just wiped down with a damp cloth, no armorall. and a sun shade used in the windshield on hot days. and it has yet to crack over the past 19 years.
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
WOW never heard of it till now, I am getting some on Monday. My convertible top will appreciate it. Although it never sees sun, cause if its sunny the top is down other wise it's in the garage. Sounds like a great product. The plastic window on my vert you can barely see through.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
most stuff is water based, used black magic stuff, its oily goop. soak the dash down with half a bottle n let it back in the sun.
dash will never crack.
Car: 1988 trans am GTA
Engine: 350 tpi
the cold cracked mine too and i live in wisconsin.... it was freezing one morning and i got in my car and started it and i watched my perfect pad crack!
Car: 1988 Pontiac Formula 350TPI HARDTOP
Engine: 04- 350 Crate Motor with Crane Cam
Axle/Gears: 10 Bolt Posi 3.73:1
Dashboard
A Dash Cover is a Good Option if all else Fails . Heres a Pic of one I have on my 3RD Gen, it's the Lay On Kind that I had to do Modifications to , but there are Also Custom Dash Covers you could Try . If You CANNOT SEE IT , Then It's Not There , Right ? Wink...
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I used Armor All protectant wipes and now im using black magic wipes. havent had any problems with the cold cracking it. I did run my knee into the corner and cracked the corner though
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
drown your dash pad in baby oil, you can stick your thumb into the dash and it won't crack. old detailers trick.. reapply a few times per year.
gta892000
Sep 16, 2015 12:37 AM
