Popup delete, flushmount lights :)
Old Mar 24, 2006 | 12:22 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Here is what i have been working on:
(It actually isnt sitting high on the left of that image, its level)
The lights are Hella 90mm Modules, currently have the H7s/ECE.
Currently the problems are only on the covers. That bend in the front refracts the light (for those in the know, i have impact angles from 90 -15, plexi in 1.51 index). I want to try and keep the lights flush, but would require something else to work.
The mounting system is really simple. 4 holes on top, enlarge the circler opening for the low beam, self tapper with spring for the bottom 1 per light.
I was looking at the C5R lights, but wanted to try and keep it below/at hood level. BTW, i know my hood and front cover are messed up, all measurements are from the original headlights.
Ideas? Comments? Suggestions?
Old Mar 24, 2006 | 12:25 PM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Do you have a zoomed out picture, one showing the whole front end?
Old Mar 24, 2006 | 12:27 PM
Car: 85 Trans Am
not yet, i just finished the one side at that point, the other side is done, but same problems persist. Ill try this weekend, im doing the wiring harness.
Old Mar 26, 2006 | 08:04 PM
Car: 85 Trans Am
Ok, i changed the cover design. Instead of going up and out i went in. I started the curve above the light. It is completely flat from about 1/2" above the light and meets the front of where the previous light ended. So now i have the defined cutoff of the projector light, and very very little of the beam is lost.
now i just need to aim the lights better
Ill try to get pics tonight.
Old Mar 26, 2006 | 09:52 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Pics? Sounds cool.
Old Mar 27, 2006 | 12:05 AM
Car: 85 Trans Am
there are some pics up top, my server is currently offline... Ill try to get pics of the new setup.
Old Mar 27, 2006 | 01:29 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
hmm i see no pictures... is it just me?
Old Mar 27, 2006 | 01:34 AM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
i also am not seeing pictures.
Old Mar 27, 2006 | 11:01 AM
Car: 85 Trans Am
They are back up
Old Mar 27, 2006 | 04:25 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Get yourself some button heads screws so they don't stand out so much. Or better yet, counter sink your holes and use flat head screws.
Old Mar 27, 2006 | 04:27 PM
Car: 85 Trans Am
I have some flush mount torx heads im going to use
Old Mar 27, 2006 | 04:59 PM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Hmm, that's not bad. Any pics from further back?
Old Jun 1, 2006 | 05:22 PM
Car: 85 Trans Am
Guess i should update i change the covers to deal with the angle
First pic is the original design, Second is the newer. No refraction.
Attached Thumbnails Popup delete, flushmount lights :)-mike-light1.gif   Popup delete, flushmount lights :)-mike-light2.gif
Old Jun 2, 2006 | 03:17 AM
Pontiaddict's Avatar
I love birds but hate popup lights so I'd like to do this someday as well.
2 suggestions on possibilities
The first would be to extend the cover to fill in the notch on the bumper and cover the turn signal as well. That would keep the cover flush with the hood yet not need to bend to follow the lines of the edge of the hood.
The second suggestion is to make a piece that had the same shape as the old headlight in the down position, then add 2 cone shaped notches to french in the new lights in their current position. While this wouldn't make them flushmounts, it would keep them under the profile of the hood and tie the new lights in with the the original styling.
Old Aug 20, 2007 | 11:17 AM
soultron's Avatar
Car: 87 trans am
Re: Popup delete, flushmount lights :)
I guess what you might mean is something like the C5R?
Don't know if it'd work, but I've thought about getting a set of 94 or so sunfire headlamps to mock up.
Just an idea really.
Old Aug 20, 2007 | 04:56 PM
Mythos's Avatar
Car: 1991 Pontiac Trans Am
Engine: LB9 305 V8
Transmission: THM 700R4
Axle/Gears: 2.73 Limited Slip
This a very Quick mock up on my car. I hope this helps.
Anyway I'm off for work.
Attached Thumbnails Popup delete, flushmount lights :)-sunfire.jpg
Old Aug 20, 2007 | 04:59 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
You should design it to cover the entire space on bumper where turn signal and headlight is. That would be great. Try to merge your idea with the cover in the following pic and see how that turns out, I think it would be awesome.
Old Aug 27, 2007 | 06:08 PM
Pocket's Avatar
Car: 91 Trans Am
Not to rain on you or discourage you, but I hate it
Pop up headlights are one of the defining features in a newer firebird
But since this is technical and not opinionated boards, heres some useful reading/suggestions
Several mods include the "lazy eye" where the headlights only move a small amount
Redraif uses a non-pop up mount similar to the method posted, but then again she has the 85-90 nose and there is quite a bit more room
I forget his name, but there was a guy in the fabrication boards about 2 years ago that made an entire tube frame front, fiberglassed a new nose similar to the original and incorporated sunfire fixed headlights
Good luck to your project
Old Aug 29, 2007 | 05:35 PM
Jessman's Avatar
Nice fab work, but I think the flip up lights go better with the overall look of the car.
Does that mod give you any better lighting than the stock flip ups?
Old Aug 29, 2007 | 06:46 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
I think they are pretty nice looking, good design and all, but like someone said above and I know you're gonna change it, I'm not a big fan of the screws sticking up.
Was that the guy who made that crazy looking front end and used the latest style sunfire lights? Not the ones in the post above. His car was black or primer or something. That looked nuts.
Old Aug 29, 2007 | 08:34 PM
Pocket's Avatar
Car: 91 Trans Am
Yes that guy, he posted a ton of pics in primer and i think he finally painted it blue or something
Old Jun 30, 2008 | 05:35 PM
Car: 85 Trans Am
fyi, have that car for sale now. Moving out of the thirdgen arena
https://www.thirdgen.org/forums/sout...ollection.html
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
Omega
Aug 10, 2015 12:46 PM
