found some rust.. what to do.
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
found this rust under my gas tank.. looks like gm decided it wasnt important enough to undercoat. this is the only rust i have on my car and it almost looks like weld splatters. anyway i need to know were to start. can i just sand it down to bare metal rattle prime and paint over it with acrylic enamel?
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
You must live in the south or west, and I envy you. That doesn't even qualify as "rust" up here!
Sand it, wire wheel it, wire brush it, whatever method you prefer to knock off the scaly/loose stuff. Then clean the area with some degreaser, apply a couple coats of Ospho acid, and after that dries, apply a coat or two of Master Series silver and the rust will never return.
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Yea I live in ny but actualy got this car in florida. So its zero rust except for this . im going to wire wheel it tommorow hopefully i can get it all ready to prep and coat. thanks!
Car: 85' Berlinetta
Engine: Twin Turbo 350 coming soon
Transmission: TH350
Axle/Gears: 10 bolt 3.42 posi
Hey, I have a 85 berlinetta too
anyway, what I do for rust, is this:
1. Wire brush hardcore
2. Sand hardcore
3. 3M pad hardcore
4. POR15 all over it
5. Sand when dry
6. Prime
7. Paint
anyway, what I do for rust, is this:1. Wire brush hardcore
2. Sand hardcore
3. 3M pad hardcore
5. Sand when dry
6. Prime
7. Paint
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Ok guys i went out and worked on it a little. Do you think its ready for the por15 or should i sand/grind it down some more? Ive heard por15 actualy works better if theres a little rust to bond to. But im kinda leary of leaving this much behind ...the metal would have to be ground to get rid of the rest and this metal is like recycled beer cans its so thin. Its weird because to my eye it looks like black spots yet the camera pics up orange... weird
Car: 86 camaro z28
Engine: 5.7 carb
sand more, the primer it with a Rust and Corrrsion Control Coating , rust is like cancer it still can come back,
i get that alot. i work for a chevy dealership painting cars, so protect it
rudolphschenker
Sep 4, 2015 02:41 AM
