Would it be possible...
Old May 16, 2006 | 08:18 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
Is it possible to replace a camaro speedo with a firebird one? I have an 89 Camaro speedo that is mechanical and it doesn't work because I have a
4L60e tranny. I am looking for a cheap alternative to get a speedo.
Old May 16, 2006 | 08:25 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
Transmission: 700-R4
Axle/Gears: 9Bolt 345'S
Please explain why a 4l60e is the root of your prob? I can help.
Old May 16, 2006 | 08:55 PM
I have an LT1 with 4l60e tranny. It's from 95. The tranny puts out a vss signal for the computer, basically I need a speedo that runs from vss.
Old May 17, 2006 | 01:00 AM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Yeah, basically the E means it's electronic and not mechanical
Old May 25, 2006 | 05:13 PM
ttt
Old Jun 7, 2006 | 09:51 AM
Nobody knows?
Old Jun 7, 2006 | 10:00 AM
Firebat's Avatar
why not replace the speedo with an electric one from a 91-92 camaro?
A firebird speedo would work but you're going to have to rewire everything and then have to get a firebird dash. I think a 91-92 camaro speedometer would be easier.
Old Jun 7, 2006 | 10:11 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
but in his sig he has a camaro...
Old Jun 7, 2006 | 10:12 AM
Firebat's Avatar
OK??
Old Jun 7, 2006 | 01:29 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
to put in a 91-92 camaro guage you will have to change all the guage sorunds and stuff as well. it would still be WAY easyer then converting to a firebird dash. also i am farley certain that the dash mounts in a camaro and firebird are different to the point that they will not match up without modifications to the mounts that are wealded to the car. the firebird speedo will NOT drop in to a mechanical camaro cluster without running all your own wires for it. you will need skills. massive skills. the best cheapest option would be to put a 91-92 camaro guage cluster in there.
also, V6sucker, we are all aware he has a camaro, he said it right in his first post. THAT is why firbat said to use the 91-92 camaro one. as it would be less complicated.
RED85TPI
Brakes
Aug 31, 2015 10:29 AM
spiffiestpengui
Mar 16, 2010 03:40 PM
greatskiiiier
Feb 11, 2010 05:33 PM
coryprine
Nov 6, 2009 04:18 PM
coryprine
South Central
Nov 4, 2009 11:35 AM
