Question about 92 hatch pull-down assembly
Old May 25, 2006 | 09:25 PM
Dolfan348454999's Avatar
Car: 92 z28
Transmission: auto
I know that there is vertually no place to get an entire pull down assembly for a 92 camaro, which I have, or a late 91. I was able to take it apart and figure out what is wrong with it. The gear nut had stripped teath. I have found that part on top-downsolutions.com, but in the process of taking it apart I broke the motor. Which brings me to my question. Can I use a 91 or earlier pull-down motor on a 92 if I get the rest of the pieces I need to fit a 92?
P.S. If anybody knows a place where I can get an entire assembly for a 92 the info would be greatly appreciated.
Old May 25, 2006 | 10:39 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
My parts manual shows them as two different part numbers, so you are out of luck. What did you break on the motor?
Old May 26, 2006 | 12:51 AM
Belker's Avatar
eBay Motors: 1982-92 CAMARO REAR HATCH PULLDOWN MOTOR IROC Z28 (item 8068783453 end time May-28-06 15:45:00 PDT)
Old May 26, 2006 | 06:34 AM
Car: 92 z28
Transmission: auto
not sure if that will fit. They say it fits 82-92 and I know that cant be right.
Old May 26, 2006 | 09:12 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I know that one on eBay won't fit yours. I have some used 91-92 pull-down units, so I can help.
Lon
Old May 26, 2006 | 01:24 PM
Car: 92 z28
Transmission: auto
Lon
I found the gearnut I need on your site, but can't find the motor. I'm I looking in the wrong place.
Old May 26, 2006 | 04:54 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I get mine from the junkyard. I got about three hatch motors, and made one good motor between them. I kept the rest for parts. Check the junkyard.
Old May 26, 2006 | 05:01 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Why wont the one on Ebay work for him if its from a 1992?
Old May 26, 2006 | 05:13 PM
Car: 92 z28
Transmission: auto
It is not from a 92. That is a mistake. The person selling that thinks the part works on cars from 82 till 92. That person doesn't know that the hatch pull-down assembly changed mid year 91. I'm guessing that person just listed it as a 92 thinking that it is
Old May 26, 2006 | 06:54 PM
Engine: LB9, LB9
oh so anything 82-90 is the same?
Old May 26, 2006 | 07:28 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
about mid year 1991 they started getting the new motor.
Old May 26, 2006 | 07:32 PM
Car: 92 z28
Transmission: auto
They also went from metal tracks to plastic tracks.
Old May 29, 2006 | 12:02 PM
GTR34CU's Avatar
wow, that's cool. my hatch assembly has been broken for a while b/c of that little gear. thanks for the link to top-downsolutions.com. i already have a gear on the way!
Old May 29, 2006 | 02:11 PM
Car: 92 z28
Transmission: auto
good
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
madsv1000
Aug 20, 2015 06:45 AM
redmaroz
Aug 16, 2015 11:40 PM
