Where can I get "GM" Keys?
Old Jun 1, 2006 | 09:16 AM
ck76239's Avatar
Car: 1982 z28, 2007 Silverado
Engine: 350 Chevy, 10-1 CR, Comp Cams 270h
Transmission: Th350,
My z28 only came with one set of keys, which are the original set. I had them copied, but typically the copies are a off brand, ie my copies say "access" on the key blank...
So, does anyone know where I could get a "GM" marked key blank set. Then if I ordered a blank set, do you think Lowes, or some other store that copies keys would allow me to provide my own blanks?
Thanks!
Old Jun 1, 2006 | 09:20 AM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Have you tried the dealer? Either the dealer or some place online should have GM blanks.
Old Jun 1, 2006 | 09:38 AM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
i got keys made at work and they had gm blanks and even ones that ae covered in plastic at the top and marked gm
Old Jun 1, 2006 | 09:40 AM
ck76239's Avatar
Getting to the dealership is difficult for me, too far to go on a lunch hour... I would much prefer to order on-line...
Thanks!
Old Jun 1, 2006 | 09:49 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
then no. They need to see your key pattern to make the new one, so it's not really something you can do online. I had one made based on my VIN once when I locked my keys into the car, and surprise surprise, it didn't work.
Just find time to hit a GM dealer. Every town in the country has some sort of GM dealer... it doesn't have to be the Chevy dealer, it can be any GM dealer.
Old Jun 1, 2006 | 11:18 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
(If available in your area) Mobile lock smith services will come to you and can duplicate the key. If you specify that you want a GM branded key they can provide that as well. Expect to pay for this type of serivce though...
Old Jun 1, 2006 | 11:47 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
He's not looking to have a key made, he just wants to buy blanks that have GM stamped on them. Since it isn't a VATS car, the blanks should be readily available. Might take some phone calls or some google searching to find them. Also might try calling the dealer and see if they would mail them if you prepaid with a credit card.
And to answer the original question, yes Lowe's or anyplace that makes keys would use your blanks.
Old Jun 1, 2006 | 01:50 PM
ck76239's Avatar
Right... not Vats system to contend with, since it's an 82...
Old Jun 1, 2006 | 02:31 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
They are all over ebay. I just bought three sets and took them to the local harware store and had them made.
eBay Motors: GM Logo keys - most 1983 83 Pontiac Trans Am (item 4641700707 end time Jun-16-06 15:10:42 PDT)
Old Jun 1, 2006 | 03:28 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
What about VATS keys? I only have one set for my '92, and if I lose them, I'm screwed.
Also, I got a spare GM door key made at ACE Hardware, and it had GM stamped on the top of the key.
Old Jun 1, 2006 | 03:44 PM
Agent13's Avatar
Engine: LG4
You need to find out what your VATS number is and then buy that key. I don't know if the dealer can still do that for you or not.
Old Jun 1, 2006 | 03:58 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
any locksmith will be able to get them
Old Jun 1, 2006 | 04:06 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
I know that you can order the regular (non VATS) keys from the paddock online, pretty sure other sellers like classic Industries, etc. carry them too.
as for getting them cut, you have a chance that lowes or Home Depot might cut it for you, you could ask, but some stores won't cut customer provided blanks.
smaller hardware stores like Ace or True-value will usually do it no problem.
Old Jun 1, 2006 | 04:20 PM
ck76239's Avatar
Thanks, I just ordered a set from a selller on flea bay, once they come in I'll see if Lowes will cut them for me....
Old Jun 1, 2006 | 05:12 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
you coulda tried moderndaymuscle.com
Old Jun 9, 2006 | 10:52 PM
Vaneat-91RS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Your GM dealer has a VATS tester and can tell you what your VATS code is for free (literally takes 10 seconds). VATS keys are a bit spendy from the dealer: $24-30 per each. Some dealers charge to cut them some don't. Likely if you bring your own keys they'll charge you for sure, if you buy the keys from them, they may not.
Take note those who want keys cut from your VIN: GM now requires proof of ownership to cut keys. This is because of the number of people who were pulling VINs from cars, getting keys made, and stealing them. As a dealer employee, I can tell you this is a real pita, but dealers can now be fined depending on local and state laws, so no matter how bad your sob story when you come in, they likely will not cut keys without documentation that you own the car (we require DL and registration or title that match).
Also, be aware on VATS cars that the wires on the ignition cylinders are prone to wear out, and replacement of the cylinder requires new keys as well since the cylinders are precoded. Another brilliant engineering triumph.
Old Jun 10, 2006 | 12:16 AM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
VATS keys are expensive. I know somebody at a GM dealer and it still cost me $45 per key with his discount.
they only sell the covers, not the keys themselves.
Last edited by MikeDirntRulez; Jun 10, 2006 at 12:16 AM. Reason: Automerged Doublepost
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
