bolt-on vs pin-on
Old Jan 30, 2007 | 04:04 PM
CamaroShifter85's Avatar
bolt-on vs pin-on
Well, I've done a little bit of looking around for hoods and learning about bolt-ons and pin-ons. I see that pin-ons are quite a bit cheaper, and i actualyl kind of like the looks of them better as well. However, there IS the bigger risk involved with it, and I plan on putting it on a daily driver as well. I don't know quite too well how it works, but is there anyway that I can make sure the pin-on stays on, like lock it somehow? I'm thinking fo getting the twin turbo hood for an '88 t/a.
Old Jan 30, 2007 | 04:31 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
pin on on a daily drive might be a PITA. your gonna have to take it off all the time just to check/change/replenish fluids etc..
The pins for pin ons stay snug so you shouldnt have to worry about it. They do make a key lock style also.
Old Jan 30, 2007 | 05:22 PM
hm.. so it's not so much a matter of safety as much as it's a matter of being a hassle then? I'm still a bit confused, when you have to open the hood with a pin on, do you have to literally take it off? Like there's no hinge or hydraulics on it at all?
Old Jan 30, 2007 | 05:39 PM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Well if there was a fire under your hood you couldn't just pop the hood and use your fire extingisher to put it out. But just a normal car doesn't usually start on fire. I think it would be a PITA checking oil and adding washer fluid, stuff like that. But it's all up to you.
Old Jan 30, 2007 | 05:42 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
There cheaper because you only get half a hood lol. If you care about your paint at all dont get a pin on. It will be a pain in the butt to take on and off. And no matter what you do you will end up scratching the paint. High speed it will shake and move around. Pin ons are for a track car not a daily driver.
Not trying to offend anyone. But, thats what it was like for me when i had one.
Save some more money and buy a bolt on.
Old Jan 30, 2007 | 05:47 PM
ok, will do. Thanks for all the information everyone. I'll stick with the bolt-on then.
Old Jan 30, 2007 | 08:46 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I have a pin on. I like it. It might be alittle more of a hassle but once it is off there is nothing in your way. Makes working under the hood much easier.
There is no point to putting locks on a pin on hood. The hood is so thin that if anyone realy wanted to they could just grab it and break it in half to get it off. Then you end up with stolen parts and a piece of junk $400 hood.
Old Jan 30, 2007 | 09:35 PM
hmm.. well about how long does it take to take off? I guess I'll have to look at one to tell for sure, but I'll keep looking around a bit.
Old Jan 30, 2007 | 09:47 PM
MavViper's Avatar
pin ons were mainly produced for racing cars due to the weight savings and also the fact the whole hood could come off which makes it easier to work on the engine.
My advice is to go with bolt on. You'll still probably have to put hood pins on it at the front to prevent the corners from coming up.
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Well mine isent painted yet so i can get it off by my self in 10-20 secs.
http://s177.photobucket.com/albums/w...t=DSCN0783.jpg
How do i post pics?
Old Jan 30, 2007 | 10:09 PM
well, why does it take longer once it's painted?
And now i'm thinking about getting a bolt on like you mentioned, then putting pins in the front, by the vents.
Old Jan 30, 2007 | 10:24 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Alright, my method of madness on my daily driver is border line to others, my car is primered, i am 6'4, i have long arms and i love the 4 pin "race" look, i love my pin on, on a bolt on i hit my head and have to lean over to get to the compartment near the cowl, so for me it is a convenience, not a hassle, i would like to have the bolt on for the ease of opening, but i will set up a extinguisher that will be activated from inside the driver compartment, so you will have to make a decision that fits you, my wife never drives the RS, she cannot drive a stick anyway so that is not an issue anyway.
Old Jan 30, 2007 | 10:44 PM
Gramps's Avatar
Car: 87 Camaro IROC
anybody heard stories about fiberglass hoods cracking because of the bolton hoods hinges and actuators putting too much pressure on it?
Old Jan 30, 2007 | 10:46 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Yea, i think harwood sells low resistance shocks to prevent this on a bolt on.
Old Jan 30, 2007 | 11:06 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Because when it is painted you need 2 people to put it on and take it off. If it bends to much you can crack your paint. It is not that it takes more time it just takes more people
Old Jan 31, 2007 | 02:35 PM
wow.. i guess they are THAT flimsy aren't they.. jeeez
Ya.. i'm not looking for too limp a hood, so bolt-on it is.
Thanks again everyone.
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
80's Al
Mar 31, 2002 07:54 AM
87kevroc
Apr 14, 2001 09:32 AM
mostafa3k
Mar 13, 2001 09:01 AM
