Body Reinforcing Areas?
Old May 15, 2007 | 08:32 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Hi all, I want to drop anywhere from 300 to 400RWHP in my 84 T.A but before I do this I want to know what the weak areas are of these cars (Where I will need to reinforce) Im good with welding and I also know someone who owns a car hoist so I can get under it easly.
Thanks in advance for any help!
Old May 15, 2007 | 09:30 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Re: Body Reinforcing Areas?
Get subframe connectors.
Old May 15, 2007 | 10:05 PM
VenomX-87's Avatar
where from and what do they do?
Is it posible to fab up something to go in there place since I live in Australia aftermarket parts for these cars is a IMPORT ONLY kinda thing and id have to pay big $$$ to get them.
Old May 16, 2007 | 06:56 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
yup do a search for homemade sfc's
Old May 17, 2007 | 06:31 PM
VenomX-87's Avatar
Thanks, I just had a quick look.
Old May 18, 2007 | 03:15 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Other common things are strut tower braces and steering braces. You can probably find a ton of pictures of strut tower braces on here, I'm not sure if you'll find any pictures of steering braces. They should be easy enough to fab up though.
Old May 18, 2007 | 10:06 PM
sgtmac's Avatar
Car: 87 Fomula, bought new, October 86
Engine: 305 Quadrajet,
Axle/Gears: 9bolt now in, starting on body work
You could fab up some sfc's with some 2 inch square tubing, hooking together the front and rear subframes. You may have to bend it some if you don't want to cut the floor for a straight shot through. You can weld the stock lower contol arms up into a solid box. A brace joining the front fenders together shouldn't be hard to work up. Also, adding poly bushings in place of the stock rubber bushings can add more responsiveness to the chassis at the expense of noise, vibration and harshness.
Old Dec 12, 2007 | 03:33 PM
VenomX-87's Avatar
I have picked up a set of SFC's from someone here is Aus (yankeecarman from www.camaro-firebird.org) and im going over the body atm while the car is striped, Im replacing almost all of the firewall/drain area because of rust (from the RHD conversion). I have pictures on my www.84transamresto.blogspot.com sight.
Here is a pic of the SFC's
http://members.optushome.com.au/ozfbody/dallas/sfc.htm
Old Dec 12, 2007 | 04:08 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
those look pretty slick!
Old Dec 12, 2007 | 04:19 PM
VenomX-87's Avatar
Yeah they are very well made and bloody solid.
Old Dec 12, 2007 | 05:29 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
haha those SFC's could probably handle jet engine LOL dam .... But will the rocker ground effects cover them.
Old Dec 12, 2007 | 05:47 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Any ground-clearance issues?
JamesC
Old Dec 12, 2007 | 06:30 PM
VenomX-87's Avatar
I don't know about the ground clearance with them installed, There is a Turbo Camaro owned by Droopz from Aus and he is using the same SFC's.
Link to Droopz's car: https://www.thirdgen.org/forums/powe...iry-turbo.html
I havent heard any problems from him regarding to body twist or ground clearance tho.
Old Dec 16, 2007 | 09:37 PM
Deaclen's Avatar
Car: 91 camaro Z28
Engine: LT4 Intake & Heads bottom end 94
Venom, those are some bad *** SFC. Yankeeman must have his hands full. What was the cost? Is there another way to get ahold of him aside from signing up for a membership at another site. I wonder if he would ship to the US.
Old Dec 16, 2007 | 09:55 PM
VenomX-87's Avatar
There is a link under the picture (above) but here it is:
and here is his E-mail:
yankeecarman@yahoo.com.au
he will be able to give you all the info you need.
EDIT: cost was $400AUD+Shipping ($348.84USD).
Im droping an easy 400HP+ infront of my trans and i want to know the body will take a fue hard launches without twisting (more power to the ground) and these look like they will give the car what it needs to do this.
Old Dec 18, 2007 | 06:31 PM
VenomX-87's Avatar
Hey I found somthing interesting while cleaning out the floor pan for a respray.
I removed all the body sealer (black) stuff that looks to be from the factory and i found a 3 to 4mm gap betwene the floor pan and the box frame under the door it looks only be joined where the seat rails go across from the center console, Is this ment to be there or not?
If it is normal it is no wonder these things twist so mutch when you put abit of power in them. Im going to get about 3 pieces of 1mm sheet metal @ 150x50mm slightly bent and weld it in over the gap on eatch side of the car to fix the floor to the outer frame for more stringth.
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
eddie jr
Aug 25, 2015 06:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
TheJoeY88
Aug 13, 2015 06:51 PM
