stripping tips?
Old Oct 25, 2007 | 08:42 PM
t/agta's Avatar
Car: 87' Trans Am GTA, 88' Trans Am GTA
stripping tips?
i think me and my friend are going to start stripping the paint off of my gta next weekend. Can anybody give me some tips or techniques on dry/wet sanding and bumper repair?
Thanks,
Rich
Old Oct 25, 2007 | 08:57 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: stripping tips?
That bumper looks a little rough,got a replacement for it?If not,I think I would locate one that has less damage.Alot less time money and effort replacing it with one in fair or good shape than trying to repair a badly damaged one.
Old Oct 25, 2007 | 09:06 PM
t/agta's Avatar
Re: stripping tips?
i dont have a replacement but this one wont be staying on it for long. We're stripping the entire car, fixing the little rust that it has, and putting it in black primer. When i get it painted this summer i will be getting new bumpers put on it before i do. The front bumper isnt really as bad as it looks. It has alot of paint blown off of it, but the only real problem is the 6 inch crack that goes from the top of the passanger side driving light and heads upwards. We were just gonna use bondo on that since the bumper is only temporary anyways.
Old Oct 25, 2007 | 09:15 PM
Stephen's Avatar
Car: 87 GTA
Re: stripping tips?
Bondo on urethane....I give it 30 days...
Old Oct 25, 2007 | 09:16 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Re: stripping tips?
I believe theres a thread in here about bumper repair thast pretty straightforward. I wouldnt bondo it even if its temp itll suck lol. Do a search on bumper repair. It should be the one where you drill some small holes and use some flexible filler.
Old Oct 25, 2007 | 09:17 PM
fenton06's Avatar
Re: stripping tips?
it's only temp, I'd bondo the hell out of it too since it is so easily replaceable.
Old Oct 25, 2007 | 09:38 PM
dsherw00d's Avatar
Car: 68 Camaro, 73 Nova, 67 Mustang
Engine: 350, 355, 289
Transmission: Muncie, 700R4, C4
Re: stripping tips?
As for taking the paint off, you can use chemical strippers or do it with sanders. You could also take it to a soda baster and have them blast it off if you want to take the car further apart. Chemical is messy and you have to be careful where you put/leave it. Sanding it is more work. I've sanded the few I have done. Use aggressive sandpaper/tools to take it down and switch to the grit your primer manufacture recommends. I user 40/80 grit on a DA.
Wet sanding is only when you get much further along - after base primer, body work, more primer, more dry sanding, more primer, ....
However, if most of your paint is still solid - I would just fix the bad spots, hit the existing paint with a DA, seal/prime, body work, prime/seal, and paint. Stripping a car to bare metal isn't always the best way - the factory primer/coating is a good base. Stripping the car will cost a bunch more. If you do strip it, do 1 panel at a time. Get the panel in Epoxy primer before starting the next.
-Dan
Old Oct 27, 2007 | 02:56 PM
t/agta's Avatar
Re: stripping tips?
thanks
Old Nov 13, 2007 | 09:36 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
Re: stripping tips?
try 2 part epoxy and then bondo over it....the epoxy will hold and keep it from flexing too much
jrdturbo
Mar 31, 2016 02:58 PM
Thaney9
Oct 15, 2015 06:37 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
Night rider327
Sep 25, 2015 04:47 AM
