Antenna Center
Old Nov 22, 2007 | 04:30 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Antenna Center
The center section of my power antenna will not extend. What do I need to repair this?
Old Nov 22, 2007 | 04:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Antenna Center
You mean it only extends part way?
Old Nov 22, 2007 | 04:59 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Re: Antenna Center
Yep
Old Nov 22, 2007 | 05:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Antenna Center
See if you can gently pull it free, and then lubricate each segment with light oil.
Old Nov 22, 2007 | 05:09 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Re: Antenna Center
Tried it w/wd40 and pulled up several times, NG.
Old Nov 22, 2007 | 05:11 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Antenna Center
perhaps a section of it is bent,causing it to bind.
Old Nov 22, 2007 | 05:12 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Antenna Center
just a thought, but in high school we were taught nopt to use oil.
The oil attracts and catches dirt adn what not which jams up the antenna.
Instead we used brake clean/degreasser and removed whatever dirt. It seemed to work pretty well.
Old Nov 22, 2007 | 06:52 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Re: Antenna Center
Not bent, manual says to use light oil.
Old Nov 22, 2007 | 07:04 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Re: Antenna Center
have you tried cleaning it with the degreasers first?
Even if you oil it up it won't really help if its all gummed up and dirty.
Old Nov 22, 2007 | 07:54 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Re: Antenna Center
I havn't removed it from the car yet. I was hoping the wd i used would loosen it up. Will check tomorrow.
Old Nov 24, 2007 | 12:28 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: Antenna Center
After using WD and exercising the antenna up and down (hopefully it will free-up and work), lightly wipe the antenna with a dry clean rag. This will remove any access oil to help prevent the dust and dirt from accumulating on it. The very light WD residual film left behind will be all it needs for lubrication (provided it's working properly).
If the above doesn't solve your problem, you then likely have an internal antenna drive mechanical issue.
Good luck.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Ed1LE
Sep 30, 2018 09:14 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
