need recomendation
Old Dec 15, 2007 | 01:54 PM
sikZ28's Avatar
Car: 86 Trans Am
need recomendation
Hey fellow 3rd gen minions, I need help with this.
Could somebody recomend a floor jack so that I can jack up the front under the k member or just under the control arm.
what I am really asking is do they make one low and long enough to reach from the front?
*Moderators*
Please put this question in the right spot if this isn't the correct forum.
Old Dec 15, 2007 | 02:42 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: need recomendation
I have not seen many over 1 or 2 ton that will fit under the car. The big and strong floor jacks are just to hight to get under there. What I do is just use a small 1 ton jack to jack the front up (works fine under the strut) enought to get my 3 ton floor jack under it. Basically, you have to jack the car up to get a jack under it . I thought my uncle was joking when he told me that until I tried it. I also thought that he was joking about getting out of the car next to a curb and falling out instead of getting out...then I did it
Old Dec 15, 2007 | 03:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
make yourself a set of ramps. Take 2- 2x12's, nail them together and cut one side on a shallow angle, then you can drive the car up on them and fit almost any floorjack under the car. Thats how i have to do mine
Old Dec 16, 2007 | 11:57 AM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
I either jack up under the control arm and then place a jack on the cross brace or i drive onto a piece of wood then do it.
Old Dec 16, 2007 | 08:30 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
While a few boards are cheaper, if you're looking for a jack, they make low profile jacks and air jacks that are thin and then inflate under the jacking point (prices can range quite dramatically as expected) . . .
This one is only 2 1/2" high and will reach anywhere you need it.
It retails for around $250 . . .
On this topic, here's a wild idea (not sure I'd want, it's but interesting) . . .
Old Dec 17, 2007 | 06:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I use a normal floor jack under the k member (an MVP Pro-lift 3 ton that I bought at an auto chain), BUT I angle in by a front tire. The opening of the well allows a jacking angle.
JamesC
Old Dec 17, 2007 | 06:39 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
We have one we bought from Canadian Tire, it's 2 1/2 inches high, 2 ton capacity, and was under 100$. Works good for lifting it high enough to get a higher jack underneath.
Old Dec 19, 2007 | 08:06 AM
sikZ28's Avatar
Car: 86 Trans Am
ok, thank you for the responses. I was just getting tired of having to use 2 jacks to jack up one side. (screw jack and then the floor jack).
Kind of gets old, if you know what I mean.
