Door hinges
Old Dec 15, 2007 | 08:43 PM
visionpb16's Avatar
Door hinges
I have a 1991 camaro and the doors have become really hard to open and close, and the bottom of the door is scraping on the body when you try to close it. I know this is a problem that happens with alot of camaros cause my friend has an 89 and his doors have similar problems. Does anyone know how to fix the problem or if i need new hinges? And how difficult it is to fix this.
Old Dec 15, 2007 | 08:51 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Door hinges
you need new door pins, the lower are available at your local auto store, the tops are available at TDS (see side sponsors).
edit: Im pretty sure this is what you need http://www.top-downsolutions.com/pro...products_id=33
Old Dec 17, 2007 | 01:15 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
Re: Door hinges
Yeah, Tmic is right, definitely pins and bushings. You might try doing the bottoms first, since they are easily (and inexpensively) replaced and see if this corrects your problems before you go and buy the TDS upper kit. I only had to do my lowers, as my top hinges didn't have any slop in them.
Old Dec 17, 2007 | 02:27 PM
visionpb16's Avatar
Re: Door hinges
how exactly do you put them in? do you just remove the lower side panel and then you can see the pins and just unbolt them?
Old Dec 17, 2007 | 02:37 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Re: Door hinges
to do the bottom you just hammer the old pin out, take the old bushings out, then put the new in. to do the top you need to take the door off (or at least I did), grind out the old pins, and put in the new ones.
Old Dec 17, 2007 | 11:10 PM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
Re: Door hinges
hell no its a mother to do the door weighs like 498564894.3 lbs. i did it 2 years ago. took 2 people
Old Dec 17, 2007 | 11:54 PM
Firebat's Avatar
Re: Door hinges
It really helps if you have the front fender off when you replace the door hinge parts. And a dremel tool.
I recommend spending the extra cash and getting the grease-able door hinge repair kits, the spring removal tool, and the door alignment tool from TDS. Thats if your hinges are shot.
Old Dec 18, 2007 | 12:00 AM
19redbird89's Avatar
Car: 1989 Pontiac Trans Am GTA
Axle/Gears: 3.23 9 bolt
Re: Door hinges
I have seen an air hammer used to push the top hing in a adjust the door up so that it does not sag. This may work for you and it will not cost you like the hinges.
Old Dec 18, 2007 | 12:06 AM
Firebat's Avatar
Re: Door hinges
If there is a lot of play(you can actually move the door up and down when the door is open), at least one of the bushings in the hinges is shot and the other bushings probably aren't that great.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Veaceonee
Sep 29, 2016 08:15 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
codeysabatini
Sep 20, 2015 11:36 AM
