82 trans am fenders on an 86?
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
ive got an 86 firebird, and a friend has some 82 trans am fenders, i was wondering how hard it would be to put these on my car, he also has the small ground effects pieces.
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: 82 trans am fenders on an 86?
direct swap...except your either going to have those ground effects pieces and no kit...unless you get the rest (bumpers, side skirts, ect.) or your going ot have holes where the kit were. As far as fenders, they are direct swap.
Engine: 2002 Ls1
Transmission: t-56
what do you mean they are just small pieces, are you saying i have to have the small gfx pieces? what you mean no kit?
oh my bad, i was reading trans am and not looking into the year. Yes they should be a direct fit/swap. No issues that i know of.
Engine: 2002 Ls1
Transmission: t-56
sweet thanks, should look good with the ram air hood i bought :-D
that it should
good luck! Have fun with those fender to bumper bolts :-p
good luck! Have fun with those fender to bumper bolts :-p Supreme Member
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
same fenders different gfx holes
82 83 84 regular t/a and s/e had the early style gfx
aero 84 had a different gfx
85-up was different again
did the '82 and '83 t/a's have ground effects?! never noticed em, unless it was just an option and the ones i saw didn't have em.
wow...can't believe i didn't notice that. i'm sorry...yea it does have something ahead of the wheels. either fill the holes if you have a regular bird or get the entire kit. But it will bolt up and should carry the body line.
Engine: 4.3L Z TBI
look closer, you cant see much of them, except in the wheel arch and along the bottom of the fender, they dont come downwards much like the aero and 85-up ones do
they are up under the front corners and are huge but lay horizontal mostly
this goes for all regular t/a and s/e
firebirds no
82 83 84 is the GFX group
85-90 is the next group
91 92 is the third
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Firechicken76 you'll have lots of holes to drill. Biggest issue is your base Firebird doesn't have the rocker brackets for the piece that goes under the door.
Hello, Michael
Aug 20, 2015 03:19 PM
