AC Box/Blower Motor Removal
Old Jan 27, 2008 | 07:43 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I was looking at the passenger side firewall on my car today and when I pulled the insulation off a little bit, I was pleasantly surprised by a 2x4'' hole in the firewall directly below the blower motor. Not too sure how I am going to fix that one, but first things first, I have to get the blower motor and ac box out.
After playing around with it for quite some time, I failed to get the ac box or blower motor off of the firewall. I removed all the bolts in the area inside the car (including the 2 behind the flap of insulation) and also removed the bolts in the engine bay. The boxes don't even feel lose at all.
Is there something special to getting these things out? I searched for about an hour and only found stuff about doing ac conversions/delete . Any help would be much appreciated.
Old Jan 27, 2008 | 08:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: AC Box/Blower Motor Removal
the gasket behind it may be stuck. Make sure you have all the bolts out, and give it a good smack and it should come loose. Its a 2 pc box, i think you can get it appart with the AC parts still inside, i never tried
Old Jan 28, 2008 | 11:50 AM
Pocket's Avatar
Car: 91 Trans Am
Some are accessed from the interior of the car
One hard to get bolt is inside the AC box and you must remove the upper section and pull the dryer out to get it
The lowermost bolt near the exhaust is usually troublesome.
Its a stud threaded into the plastic while you must remove the nut in the engine bay
The stud will often strip out the plastic and just spin making things difficult
Most people just say F-it and rip the box out when this happens
Old Feb 15, 2008 | 07:18 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Sorry to bring the thread back from the dead, but I finally had a chance to get back to this today. I took off the top part of the AC box but then noticed that the entire box is somehow plastered to the firewall. Is this some kind of sealing/mounting adhesive?
My main question is, can I get the box off without damaging it and put it back on with not to many problems?
Old Feb 16, 2008 | 12:43 AM
Pocket's Avatar
Car: 91 Trans Am
The sealer foam is in there
If its stuck on there you can use a putty knife to separate it
Its not that big of a deal
Old Feb 16, 2008 | 07:59 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Ok, thanks for the help. I tried pulling the box off and saw the firewall try to come with it and had one of these moments: . I'll just use a putty knife then
Old Feb 16, 2008 | 09:49 AM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
If you have a blow dryer or a heat gun use it, it will make the removal much easier and less likely to break the box.
Old Feb 16, 2008 | 07:15 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
I ended up just using a chisel to side between the box and the firewall to get it off. It went a lot smoother than I thought that it would.
I noticed that there seems to be a gasket for the upper section of the box, is this something that I can purchase to replace the old one?
Thanks again
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Aug 15, 2015 10:47 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
